It was the opposite. With the FP400 Connected to the M100 with Thread and then shared to the Hubitat with matter all features work.
What you did was basically option 2 from my post above.
I did have to adjust the driver of the FP400 on the Hubitat after paired with Matter though.
Repaired the FP400 using matter to the M100. The shared the FP400 with Matter to Habitat. Everything seems to be working so far... Thanks for the input and sharing this information.
Re-reading the above, it sounds like this is working for everyone with the "Generic Matter Motion/Light Sensor" if they have it paired via Matter? If so, does anyone have the fingerprint handy so it could be added to the driver?
If illuminance isn't working for anyone, I'd (make sure the device is functional/online and then) run a "Configure" command to see if that helps. Having the right driver from the start might help, too, though, if it doesn't already pair that way.
I installed this using Thread via an M100 hub, then added it to Hubitat via Matter. It was originally recognized just as "Device," so I changed it to Generic Matter Motion/Light Sensor, but the only reporting it's showing is network status. None of the zones I created in the Aqara app were imported either.
I notice in the Aqara app when I go to the M100 hub, under Child Devices it lists 0. Should it be showing the FP400? Under the FP400 card, it shows that it's connected to the hub and under Matter Connected Ecosystems it shows Aqara Home.
Thanks!
Disregard. I just need to hit Configure under Commands. That updated it and brought in the zones as well as luminance.
