Driver share?
Will share after 1-2 hours.. still not quite ready, but the most important - the successful initialization worked, after a lot of black magic code!
You the man
Development branch version 1.2.0 time stamp 2022/07/28 10:50 PM is uploaded on GitHub
It is needed to pair the Aqara FP1 sensor two times to HE hub, the first pairing process usually fails.
The first change tomorrow will be to change the 'presence' attribute to the commonly used 'motion' (active/inactive). There are still a lot of things to be tested and fixed, but the most important question is whether the pairing will be successful in other HE environments.
Excellent! I ordered one to play with earlier this week. Now even more excited to get my hands in it!
Using your newest driver, I two can see motion now. Seems to be working, but did need to pair the sensor three times to get it stable.
This is cool progres
It takes about 6 seconds after the 'enter' event, before the sensor reports 'present'...
So the 'motion active' event that I am going to add should be triggered from the enter event.
'presence' will stay as a custom attribute (not as HE standard capability).
It seems to have lagg with motion indeed, but so is the temperature attribute.
So far in testing, it is not yet that sensitive. Sitting still mages the presence flip to non present.
Temperature calibration works (had te set it to -5
Add to the bugs-to-be-fixed backlog.
This is the FP1 internal chip measured temperature, and I don't know how close it is to the ambient temperature in the room. Unlike the battery-powered motion sensors, this one consumes much more power because of the digital signal processing that is performed locally in the sensor processor, so the silicon chip temperature may vary with the CPU load.
The internal sensor resolution is 1 degree, no decimal fraction.
I tried connecting FP1.
Summary
dev:47982022-07-29 09:01:11.395 pm debugAqara FP1 sending ZigbeeCommands : [he wattr 0x4006 0x01 0xFCC0 0x010C 0x20 {02} {115F}, delay 200, he wattr 0x4006 0x01 0xFCC0 0x0102 0x20 {01} {115F}, delay 200, he wattr 0x4006 0x01 0xFCC0 0x0146 0x20 {02} {115F}, delay 200, he wattr 0x4006 0x01 0xFCC0 0x0144 0x20 {00} {115F}, delay 200]
dev:47982022-07-29 09:01:11.393 pm debugAqara FP1 setting monitoringMode to 0
dev:47982022-07-29 09:01:11.391 pm debugAqara FP1 setting approachDistance to 2
dev:47982022-07-29 09:01:11.389 pm debugAqara FP1 setting motionRetriggerInterval to 1
dev:47982022-07-29 09:01:11.386 pm debugAqara FP1 setting motionSensitivity to 2
dev:47982022-07-29 09:01:11.385 pm infoAqara FP1 Debug logging is will be turned off after 24 hours
dev:47982022-07-29 09:01:11.359 pm infoAqara FP1 Debug logging is true; Description text logging is true
dev:47982022-07-29 09:01:11.358 pm infoAqara FP1 Updating Aqara P1 Motion Sensor model lumi.motion.ac01 manufacturer aqara (driver version 1.2.0 2022/07/29 2:03 PM)
dev:47982022-07-29 09:00:54.519 pm warnAqara FP1 if no more logs, please pair the device again to HE!
dev:47982022-07-29 09:00:54.476 pm infoAqara FP1 InitializeVars... fullInit = true (driver version 1.2.0 2022/07/29 2:03 PM)
dev:47982022-07-29 09:00:54.460 pm infoAqara FP1 configure...(driver version 1.2.0 2022/07/29 2:03 PM)
dev:47982022-07-29 09:00:53.462 pm warnAqara FP1 if no more logs, please pair the device again to HE!
dev:47982022-07-29 09:00:53.377 pm infoAqara FP1 InitializeVars... fullInit = true (driver version 1.2.0 2022/07/29 2:03 PM)
dev:47982022-07-29 09:00:53.353 pm infoAqara FP1 configure...(driver version 1.2.0 2022/07/29 2:03 PM)
dev:47982022-07-29 09:00:30.038 pm infoAqara P1 Motion Sensor Received ZCL Default Response to Command 02 for cluster:FCC0 , data=[02, 80] (Status: Failure)
dev:47982022-07-29 09:00:30.034 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4006 00 00 0000 0B 01 0280, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4006, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[02, 80]]
dev:47982022-07-29 09:00:30.031 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 4006 00 00 0000 0B 01 0280
dev:47982022-07-29 09:00:29.945 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47982022-07-29 09:00:29.943 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4006 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4006, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47982022-07-29 09:00:29.940 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 4006 00 01 115F 04 01 00
dev:47982022-07-29 09:00:29.925 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47982022-07-29 09:00:29.923 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4006 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4006, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47982022-07-29 09:00:29.922 pm infoAqara P1 Motion Sensor is present
dev:47982022-07-29 09:00:29.919 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 4006 00 01 115F 04 01 00
dev:47982022-07-29 09:00:29.642 pm warnAqara P1 Motion Sensor Unprocessed FCC0 attribute report: cluster=FCC0 attrId=00FF value=CA96F22285F8ABB88E747E741A87F9D4 status=null data=null
dev:47982022-07-29 09:00:29.638 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:400601FCC028FF004110CA96F22285F8ABB88E747E741A87F9D4, dni:4006, endpoint:01, cluster:FCC0, size:28, attrId:00FF, encoding:41, command:0A, value:CA96F22285F8ABB88E747E741A87F9D4, clusterInt:64704, attrInt:255]
dev:47982022-07-29 09:00:29.634 pm debugAqara P1 Motion Sensor parse: description is read attr - raw: 400601FCC028FF004110CA96F22285F8ABB88E747E741A87F9D4, dni: 4006, endpoint: 01, cluster: FCC0, size: 28, attrId: 00FF, encoding: 41, command: 0A, value: 10CA96F22285F8ABB88E747E741A87F9D4
dev:47982022-07-29 09:00:29.612 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47982022-07-29 09:00:29.610 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4006 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4006, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47982022-07-29 09:00:29.607 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 4006 00 01 115F 04 01 00
dev:47982022-07-29 09:00:29.281 pm warnAqara P1 Motion Sensor if no more logs, please pair the device again to HE!
dev:47982022-07-29 09:00:29.229 pm infoAqara P1 Motion Sensor configure...(driver version 1.2.0 2022/07/29 2:03 PM)
dev:47982022-07-29 09:00:29.220 pm warnaqaraBlackMagic() for FP1
dev:47982022-07-29 09:00:29.218 pm infoAqara P1 Motion Sensor installed() model lumi.motion.ac01 manufacturer aqara driver version 1.2.0 2022/07/29 2:03 PM
I tried to reconnect with HE.
Summary
dev:47992022-07-29 09:09:29.043 pm debugAqara FP1 sending ZigbeeCommands : [he wattr 0x8CC8 0x01 0xFCC0 0x010C 0x20 {03} {115F}, delay 200, he wattr 0x8CC8 0x01 0xFCC0 0x0102 0x20 {01} {115F}, delay 200, he wattr 0x8CC8 0x01 0xFCC0 0x0146 0x20 {02} {115F}, delay 200, he wattr 0x8CC8 0x01 0xFCC0 0x0144 0x20 {00} {115F}, delay 200]
dev:47992022-07-29 09:09:29.041 pm debugAqara FP1 setting monitoringMode to 0
dev:47992022-07-29 09:09:29.038 pm debugAqara FP1 setting approachDistance to 2
dev:47992022-07-29 09:09:29.036 pm debugAqara FP1 setting motionRetriggerInterval to 1
dev:47992022-07-29 09:09:29.023 pm debugAqara FP1 setting motionSensitivity to 3
dev:47992022-07-29 09:09:29.021 pm infoAqara FP1 Debug logging is will be turned off after 24 hours
dev:47992022-07-29 09:09:28.988 pm infoAqara FP1 Debug logging is true; Description text logging is true
dev:47992022-07-29 09:09:28.987 pm infoAqara FP1 Updating Aqara P1 Motion Sensor model lumi.motion.ac01 manufacturer aqara (driver version 1.2.0 2022/07/29 2:03 PM)
dev:47992022-07-29 09:08:39.636 pm debugAqara P1 Motion Sensor sending ZigbeeCommands : [he raw 0x8CC8 1 0x01 0xFCC0 {04 5F 11 00 00 0C 01 42 01 44 01 46 01}, delay 200]
dev:47992022-07-29 09:08:39.633 pm warnaqaraReadAttributes() FP1
dev:47992022-07-29 09:08:10.198 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47992022-07-29 09:08:10.195 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8CC8, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47992022-07-29 09:08:10.193 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00
dev:47992022-07-29 09:08:10.151 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47992022-07-29 09:08:10.148 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8CC8, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47992022-07-29 09:08:10.146 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00
dev:47992022-07-29 09:08:09.965 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47992022-07-29 09:08:09.962 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8CC8, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47992022-07-29 09:08:09.960 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00
dev:47992022-07-29 09:08:09.790 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47992022-07-29 09:08:09.788 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8CC8, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47992022-07-29 09:08:09.787 pm infoAqara P1 Motion Sensor is present
dev:47992022-07-29 09:08:09.784 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00
dev:47992022-07-29 09:08:09.741 pm warnAqara P1 Motion Sensor Unprocessed FCC0 attribute report: cluster=FCC0 attrId=00FF value=CA96F22285F8ABB88E747E741A87F9D4 status=null data=null
dev:47992022-07-29 09:08:09.738 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:8CC801FCC028FF004110CA96F22285F8ABB88E747E741A87F9D4, dni:8CC8, endpoint:01, cluster:FCC0, size:28, attrId:00FF, encoding:41, command:0A, value:CA96F22285F8ABB88E747E741A87F9D4, clusterInt:64704, attrInt:255]
dev:47992022-07-29 09:08:09.735 pm debugAqara P1 Motion Sensor parse: description is read attr - raw: 8CC801FCC028FF004110CA96F22285F8ABB88E747E741A87F9D4, dni: 8CC8, endpoint: 01, cluster: FCC0, size: 28, attrId: 00FF, encoding: 41, command: 0A, value: 10CA96F22285F8ABB88E747E741A87F9D4
dev:47992022-07-29 09:08:09.723 pm infoAqara P1 Motion Sensor Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:47992022-07-29 09:08:09.720 pm debugAqara P1 Motion Sensor parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8CC8, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:47992022-07-29 09:08:09.718 pm debugAqara P1 Motion Sensor parse: description is catchall: 0104 FCC0 01 01 0040 00 8CC8 00 01 115F 04 01 00
dev:47992022-07-29 09:08:09.617 pm warnAqara P1 Motion Sensor if no more logs, please pair the device again to HE!
dev:47992022-07-29 09:08:09.566 pm infoAqara P1 Motion Sensor configure...(driver version 1.2.0 2022/07/29 2:03 PM)
dev:47992022-07-29 09:08:09.557 pm warnaqaraBlackMagic() for FP1
dev:47992022-07-29 09:08:09.555 pm infoAqara P1 Motion Sensor installed() model lumi.motion.ac01 manufacturer aqara driver version 1.2.0 2022/07/29 2:03 PM
Possible bug found: I set the motion sensitivity to high, and after a few hours it seems to reset itself to low.
Thank you, this bug is also on my list.
I will update the version later tonight , after 5-6 hours probably.
@jw970065 your device seems to be not paired OK yet.
Try to reset it first: keep the pair button pressed for about 30 seconds. It will first flash 3 times quickly, continue pressing, will flash 14 times slowly, and finally will be lit for about half a second. Release the button at this time, the sensor should be reset.
Then put HE in Zigbee pairing mode and pair it again, releasing the button after 4-5 seconds when the LED flashes quickly 3 times.
Pair the FP1 sensor close to the HE hub.
I succeeded in pairing by making numerous attempts.
At first, there was an uneasy connection. But it seems to have been normalized one by one after a while.
Summary
dev:48022022-07-29 09:53:53.135 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:48022022-07-29 09:53:53.133 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:48022022-07-29 09:53:53.130 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00
dev:48022022-07-29 09:53:52.901 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:48022022-07-29 09:53:52.898 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:48022022-07-29 09:53:52.893 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00
dev:48022022-07-29 09:53:52.699 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[86, 02, 01] (Status: Failure)
dev:48022022-07-29 09:53:52.696 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 860201, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[86, 02, 01]]
dev:48022022-07-29 09:53:52.693 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 860201
dev:48022022-07-29 09:53:52.511 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:48022022-07-29 09:53:52.508 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:48022022-07-29 09:53:52.505 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00
dev:48022022-07-29 09:53:52.416 pm debug Aqara fp1 sending ZigbeeCommands : [he wattr 0x4C16 0x01 0xFCC0 0x010C 0x20 {01} {115F}, delay 200, he wattr 0x4C16 0x01 0xFCC0 0x0102 0x20 {01} {115F}, delay 200, he wattr 0x4C16 0x01 0xFCC0 0x0146 0x20 {03} {115F}, delay 200, he wattr 0x4C16 0x01 0xFCC0 0x0144 0x20 {00} {115F}, delay 200]
dev:48022022-07-29 09:53:52.415 pm debug Aqara fp1 setting monitoringMode to 0
dev:48022022-07-29 09:53:52.413 pm debug Aqara fp1 setting approachDistance to 3
dev:48022022-07-29 09:53:52.411 pm debug Aqara fp1 setting motionRetriggerInterval to 1
dev:48022022-07-29 09:53:52.408 pm debug Aqara fp1 setting motionSensitivity to 1
dev:48022022-07-29 09:53:52.407 pm info Aqara fp1 Debug logging is will be turned off after 24 hours
dev:48022022-07-29 09:53:52.245 pm info Aqara fp1 Debug logging is true; Description text logging is true
dev:48022022-07-29 09:53:52.244 pm info Aqara fp1 Updating Aqara P1 Motion Sensor model lumi.motion.ac01 manufacturer aqara (driver version 1.2.0 2022/07/29 2:03 PM)
dev:48022022-07-29 09:53:24.164 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:48022022-07-29 09:53:24.162 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:48022022-07-29 09:53:24.159 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00
dev:48022022-07-29 09:53:23.959 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:48022022-07-29 09:53:23.956 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:48022022-07-29 09:53:23.953 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00
dev:48022022-07-29 09:53:23.762 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[86, 02, 01] (Status: Failure)
dev:48022022-07-29 09:53:23.759 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 860201, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[86, 02, 01]]
dev:48022022-07-29 09:53:23.756 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 860201
dev:48022022-07-29 09:53:23.555 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:48022022-07-29 09:53:23.552 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:48022022-07-29 09:53:23.549 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00
dev:48022022-07-29 09:53:23.475 pm debug Aqara fp1 sending ZigbeeCommands : [he wattr 0x4C16 0x01 0xFCC0 0x010C 0x20 {01} {115F}, delay 200, he wattr 0x4C16 0x01 0xFCC0 0x0102 0x20 {01} {115F}, delay 200, he wattr 0x4C16 0x01 0xFCC0 0x0146 0x20 {03} {115F}, delay 200, he wattr 0x4C16 0x01 0xFCC0 0x0144 0x20 {00} {115F}, delay 200]
dev:48022022-07-29 09:53:23.473 pm debug Aqara fp1 setting monitoringMode to 0
dev:48022022-07-29 09:53:23.471 pm debug Aqara fp1 setting approachDistance to 3
dev:48022022-07-29 09:53:23.468 pm debug Aqara fp1 setting motionRetriggerInterval to 1
dev:48022022-07-29 09:53:23.465 pm debug Aqara fp1 setting motionSensitivity to 1
dev:48022022-07-29 09:53:23.464 pm info Aqara fp1 Debug logging is will be turned off after 24 hours
dev:48022022-07-29 09:53:23.426 pm info Aqara fp1 Debug logging is true; Description text logging is true
dev:48022022-07-29 09:53:23.425 pm info Aqara fp1 Updating Aqara P1 Motion Sensor model lumi.motion.ac01 manufacturer aqara (driver version 1.2.0 2022/07/29 2:03 PM)
dev:48022022-07-29 09:53:16.139 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[86, 02, 01] (Status: Failure)
dev:48022022-07-29 09:53:16.137 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 860201, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[86, 02, 01]]
dev:48022022-07-29 09:53:16.134 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 860201
dev:48022022-07-29 09:53:15.927 pm info Aqara fp1 Received Write Attribute Response for cluster:FCC0 , data=[00] (Status: Success)
dev:48022022-07-29 09:53:15.925 pm debug Aqara fp1 parse: Desc Map: [raw:catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00, profileId:0104, clusterId:FCC0, clusterInt:64704, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4C16, isClusterSpecific:false, isManufacturerSpecific:true, manufacturerId:115F, command:04, direction:01, data:[00]]
dev:48022022-07-29 09:53:15.922 pm debug Aqara fp1 parse: description is catchall: 0104 FCC0 01 01 0040 00 4C16 00 01 115F 04 01 00
dev:48022022-07-29 09:53:15.848 pm debug Aqara fp1 sending ZigbeeCommands : [he wattr 0x4C16 0x01 0xFCC0 0x010C 0x20 {01} {115F}, delay 200, he wattr 0x4C16 0x01 0xFCC0 0x0102 0x20 {01} {115F}, delay 200]
dev:48022022-07-29 09:53:15.846 pm debug Aqara fp1 setting motionRetriggerInterval to 1
dev:48022022-07-29 09:53:15.844 pm debug Aqara fp1 setting motionSensitivity to 1
dev:48022022-07-29 09:53:15.843 pm info Aqara fp1 Debug logging is will be turned off after 24 hours
dev:48022022-07-29 09:53:15.808 pm info Aqara fp1 Debug logging is true; Description text logging is true
dev:48022022-07-29 09:53:15.807 pm info Aqara fp1 Updating Aqara P1 Motion Sensor model lumi.motion.ac01 manufacturer aqara (driver version 1.2.0 2022/07/29 2:03 PM)
"No selection" is not selected.
The settings in the picture below are also arbitrarily changed.
