Recently I bought my hubitat elevation.
Before I was using a polish product called Zamel Extafree. (closed system which uses one way micro-wifi communication)
Most relay's I have replaced with new z-wave and zigbee relay's.
For roller shutters I would like to leave the old relay's as I got 12... Anyway I'm using them with local function. (In the evening all close and in the morning open at once )
Aqara's 2 outputs are connected with Zamel's 2 inputs.
I have added Aqara's drivers code to hubitat: Aqara Wall Switch (QBKG11LM, QBKG12LM, neutral), Double relay (LLZKMK11LM) + Generic Child Switch
Thought that's it...
Now the problem
Zamel Extafree relay's open/close via 2 channels (open via channel 1, close via channel 2, monostable). So I can't program the normal zigbee way ON/OFF. As turning ON will power on input/channel 1 (zamel transmitter), OFF will turn off the same channel.
The Aqara relay got 2 outputs, so I should be able to achieve my goal....
Is it possible to merge both generic child switches into one?
so ON = output 1 (child switch 1 monostable), OFF = output 2 (child switch 2, monostable)
and finally I will have 1 Switch in the dashboard for ON/OFF?
I'm an amateur if it comes to programming... so would really appreciate any help !!
Nope, but the old system isn't a problem, as I control all shutters it via Zamel's transmitter inputs.
Just need to get both Aqara's child devices into one in Hubitat.
Those outputs will control Zamel's 2 inputs/channels.
Just did it and it might solve the problem. It's almost working.
Current conditions:
Turn ON Virtual Device = Turn On Switch - Child Relay 1
Turn OFF Virtual Device = Turn On Switch - Child Relay 2
How I can set those child switches to monostable, so I get this outcome?
Turn ON Virtual Device = Turn On & Off Switch - Child Relay 1
Turn OFF Virtual Device = Turn On & Off Switch - Child Relay 2
For now did it this way and its working, but I think it's the noobest way ever
