Hi there.
I just received an Aqura button, the WXKG11LM model. I installed the driver from this awsome user [Release] Xiaomi / Aqara device drivers.
I got it to work. Turn on/off some hue lights with a single press, setup in ''simple lighting'' Then I tried to setup a dimmerlevel with a double press but can't get it to work. When I look under the device I can see that HE register up to 4 presses on the button.
Is it simply not supported in the driver or what?
What to do?
Button number doesn't change until the next time its used.
Look at my previous post. The last line says : pushed : 2. When I push the buttom 2 times it stays like that. When I push it one time it says 1 for maybe 2 sek and, then return to default state witch is 0
In Simple Lighting, how is the button set up?
I think I also posted that in my last post. If it's not thorough enough I'll be happy to give u more info.
I see no reason why it wouldn't work, although I know why mine wont work, every single Xiaomi device has dropped off my network again, second time this week.
