Have you guys had luck with this doing Temp/Energy/Contact? None of those are forwarding to my database.
Hey, yesterday my temperature sensors (but nothing else) stopped reporting to the InfluxDB. At first I thought it was a problem with the ESP8266 setup I'm using for this and it took my a looong time to figure out the real problem.
At least for me, the InfluxDB logger app logged a unique "hubName" for every entry. There is a standard config in Influx (which can be changed) that limits the unique tag values (not "value values") to 100,000. As every temperature reading created a unique hubName, the whole thing crapped out after 100,000 readings.
I don't know why this is happening, but I simply set the hubName to "Home Hub" permanently in the app code.
Maybe my experience helps someone else.
Is this working for people? Iām not logging anything to my bd, is there a link to the latest code with the fixes?
I just got this working. I had to remove a ".encodeAsBase64().toString()" on line 761 and now everything is reporting. Hope this helps.
