Has anybody had a case of missing Apps from the App list? This is the 2nd time this has happended to me on 2 different C7 hubs, one running 2.3.3 and now 2.3.4.130
List on Current hub:
Loaded the backup to a different hub:
Alan
Alan
I haven't seen this. I'd rule out the easy things first: any search/filter terms typed in the upper right of the Apps page? Otherwise, try downloading a new backup and restoring it to this hub (no need to reset at all before this anymore, though you'll often see that in older advice; if you do anyway, definitely do not reset the radios) in the Settings > Backup and Restore page. That may help "clean up" your database in the event that this behavior is caused by corruption.
Like @bertabcd1234 mentioned...
Could this be your problem? Do you have a filter applied at the top of the Apps page?
Yes, I just realized I was using the find filter function. Funny, my doesn't show the same message (filtered from), so other than the fiiter field, there was no indication of this.
That was from your screenshot...?
Again, RTFS! It's on the bottom of the screen! Not the first, won't be the last!
And you won't be the only one.... We've all been there.... No judgement here....
