I am seeing some errors in the past logs associated with an app:33. How do I tell which app is #33.
When you see the error in the logs, click on 'app:33'. This will then highlight the app in the list you have above the logs.
This will then tell you which app it is.
Thank you.
It would also be nice to be able to see the line 133 part of the error. Which line are they talking about. (I coincidentally also have a lot of errors on line 133)
Clear, @btjohnston76. I know which app I have, giving me the error. Now, where do I find this "line"?
Thatβs referring to the line of code that is resulting in the error.
Is it a user-created app that you added to the hub? If so, you can look for the referenced line # in the code.
It's a child app from "Groups and scenes" called "Family Room". The group contains 3 dimmers, a bulb and one switch. I might just delete this group and assign the actions to the individual devices. It's version 2.0 of the built in app fwiw. I think I saw mention of version 2.1 somewhere, but I am up to date with my hubitat software so perhaps I am mistaken.
