App does not exist
After upgrading to C8 latest version, I had some problems so I decided to do a soft reset and restore NOTHING, so no app, no device.
I'm getting this message every minute or two:
sys:12023-03-09 03:40:44.164 PMwarnReceived local request for App 1595 that does not exist, path: /modes from unknown
How come it's possible ?
its a cloud app that you previously configured and now that you reset the hub it is still trying to connect with the hub but there is no driver for it to connect to.
Even it says LOCAL request ? Ha ok
No, it's definitely a local app. Maker API is one possible app (it uses this endpoint; there may be other), so anything you set up previously using that would be a good place to start.
As I said after soft reset there is no app and no device.
Right. You configured something outside the hub that is still referring to an app you no longer have. The solution is to find that external thing and stop it.
or to successfully restore his hub and all its apps!
Ok anyway, when my problem is solved I will restore all apps anyway. But that strange it mentions LOCAL request and not CLOUD request. But that's ok.
Thank's
This is not strange. It is, in fact, local. :slight_smile:
Do you use Node Red along with Maker API? That is what happened with my transition.
Nope
Got any servers (like for Echo Speaks v4) running on, say, your NAS in a Docker container? or RPi?
I think you just find it ! For echospeaks a container is running ! Thank's buddy !
