It worked on Smartthings, let's test it to see how it will work here.
I've already been able to modify some parts of the code to work.
I'm having a problem with the status of the commands. I managed to modify it for most of them to work, however, I am not able to obtain status of the operation. Could someone please take a look at the code to see what is wrong?
Thank you very much in advance
I believe that the main problem is that the status of the device is not changing from shutdown to on
I adapted this official Zemismart DH for touch switches, but I am constantly having this error in the logs, is there any way to fix it?
Hubitat does not use the "Health Check" capability that ST uses. Here is your driver with the unnecessary bits commented out. After changing your driver to this version, be sure to view the Parent Device and click SAVE under the user settings section as I added an "unschedule()" call in the "updated()" routine to make sure the HealthCheck schedule is disabled.
* Zemi ZigBee Switch - touch
* Copyright 2020 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not
* use this file except in compliance with the License. You may obtain a copy
* of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
* License for the specific language governing permissions and limitations
* under the License.
* author : fuls@naver.com
public static String version() { return "v0.0.2.20200426" }
* 2020/04/26 >>> v0.0.2.20200426 - Support to old Jemi swtich version
* 2020/04/25 >>> v0.0.1.20200425 - Initialize
import java.lang.Math
metadata {
definition(name: "Zemi ZigBee Switch (Touch)", namespace: "zemismart", author: "Onaldo", ocfDeviceType: "oic.d.switch", vid: "generic-switch", genericHandler: "ZLL") {
capability "Actuator"
capability "Configuration"
capability "Refresh"
// capability "Health Check"
capability "Switch"
command "childOn", ["string"]
command "childOff", ["string"]
// Zemi ZigBee Multi Switch
fingerprint profileId: "0104", deviceId: "0002", inClusters: "0000, 0003, 0004, 0005, 0006", manufacturer: "Feibit Inc co.", model: "FB56+ZSW1GKJ2.5", deviceJoinName: "Zemi Zigbee Switch"
fingerprint profileId: "0104", deviceId: "0002", inClusters: "0000, 0004, 0005, 0006", outClusters: "0000", manufacturer: "Feibit Inc co.", model: "FB56+ZSW1HKJ2.5", deviceJoinName: "Zemi Zigbee Switch 1"
fingerprint profileId: "0104", deviceId: "0002", inClusters: "0000, 0003, 0004, 0005, 0006", manufacturer: "Feibit Inc co.", model: "FB56+ZSW1IKJ2.5", deviceJoinName: "Zemi Zigbee Switch 1"
fingerprint profileId: "0104", deviceId: "0002", inClusters: "0000, 0003, 0004, 0005, 0006", manufacturer: "Feibit Inc co.", model: "FB56+ZSW1GKJ2.7", deviceJoinName: "Zemi Zigbee Switch"
fingerprint profileId: "0104", deviceId: "0002", inClusters: "0000, 0004, 0005, 0006", outClusters: "0000", manufacturer: "Feibit Inc co.", model: "FB56+ZSW1HKJ2.7", deviceJoinName: "Zemi Zigbee Switch 1"
fingerprint profileId: "0104", deviceId: "0002", inClusters: "0000, 0003, 0004, 0005, 0006", manufacturer: "Feibit Inc co.", model: "FB56+ZSW1IKJ2.7", deviceJoinName: "Zemi Zigbee Switch 1"
fingerprint profileId: "C05E", deviceId: "0000", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "FeiBit", model: "FNB56-ZSW01LX2.0", deviceJoinName: "Zemi Zigbee Switch"
fingerprint profileId: "C05E", deviceId: "0000", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "FeiBit", model: "FNB56-ZSW02LX2.0", deviceJoinName: "Zemi Zigbee Switch 1"
fingerprint profileId: "C05E", deviceId: "0000", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "FeiBit", model: "FNB56-ZSW03LX2.0", deviceJoinName: "Zemi Zigbee Switch 1"
fingerprint profileId: "C05E", deviceId: "0000", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "3A Smart Home DE", model: "LXN-1S27LX1.0", deviceJoinName: "Zemi Zigbee Switch"
fingerprint profileId: "C05E", deviceId: "0000", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "3A Smart Home DE", model: "LXN-2S27LX1.0", deviceJoinName: "Zemi Zigbee Switch 1"
fingerprint profileId: "C05E", deviceId: "0000", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "3A Smart Home DE", model: "LXN-3S27LX1.0", deviceJoinName: "Zemi Zigbee Switch 1"
preferences {
input type: "paragraph", element: "paragraph", title: "Version", description: version(), displayDuringSetup: false
// simulator metadata
simulator {
// status messages
status "on": "on/off: 1"
status "off": "on/off: 0"
// reply messages
reply "zcl on-off on": "on/off: 1"
reply "zcl on-off off": "on/off: 0"
tiles(scale: 2) {
multiAttributeTile(name: "switch", type: "lighting", width: 6, height: 4, canChangeIcon: true) {
tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.light.on", backgroundColor: "#00A0DC", nextState: "turningOff"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.light.off", backgroundColor: "#ffffff", nextState: "turningOn"
attributeState "turningOn", label: '${name}', action: "switch.off", icon: "st.switches.light.on", backgroundColor: "#00A0DC", nextState: "turningOff"
attributeState "turningOff", label: '${name}', action: "switch.on", icon: "st.switches.light.off", backgroundColor: "#ffffff", nextState: "turningOn"
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label: "", action: "refresh.refresh", icon: "st.secondary.refresh"
main "switch"
details(["switch", "refresh"])
def isUnexpectedEndpoint(String model) {
switch (model) {
case 'FB56+ZSW1HKJ2.5':
case 'FB56+ZSW1IKJ2.5':
case 'FB56+ZSW1HKJ2.7':
case 'FB56+ZSW1IKJ2.7': return true
default : return false
def installed() {
log.debug "installed()"
def endpointCount = getEndpointCount()
if (endpointCount == 1) {
// for 1 gang switch - ST Official local dth
setDeviceType("ZigBee Switch")
} else if (endpointCount > 1) {
def model = device.getDataValue("model")
if (isUnexpectedEndpoint(model)) {
device.updateDataValue("endpointId", "10")
// for multi switch, cloud device
createChildDevices()
updateDataValue("onOff", "catchall")
refresh()
def updated() {
log.debug "updated()"
unschedule()
refresh()
Map eventMap = zigbee.getEvent(description)
Map eventDescMap = zigbee.parseDescriptionAsMap(description)
if (!eventMap && eventDescMap) {
eventMap = [:]
if (eventDescMap?.clusterId == zigbee.ONOFF_CLUSTER) {
eventMap[name] = "switch"
eventMap[value] = eventDescMap?.value
if (eventMap) {
def endpointId = device.getDataValue("endpointId")
log.debug "eventMap $eventMap | eventDescMap $eventDescMap"
if (eventDescMap?.sourceEndpoint == endpointId) {
log.debug "parse - sendEvent parent $eventDescMap.sourceEndpoint"
sendEvent(eventMap)
} else {
log.debug "parse - sendEvent child $eventDescMap.sourceEndpoint"
def childDevice = childDevices.find {
it.deviceNetworkId == "$device.deviceNetworkId:${eventDescMap.sourceEndpoint}"
if (childDevice) {
childDevice.sendEvent(eventMap)
} else {
log.debug "Child device: $device.deviceNetworkId:${eventDescMap.sourceEndpoint} was not found"
def parentEndpointInt = zigbee.convertHexToInt(endpointId)
def childEndpointInt = zigbee.convertHexToInt(eventDescMap?.sourceEndpoint)
def childEndpointHexString = zigbee.convertToHexString(childEndpointInt, 2).toUpperCase()
def deviceLabel = "${device.displayName[0..-2]}"
def deviceIndex = Math.abs(childEndpointInt - parentEndpointInt) + 1
createChildDevice("$deviceLabel$deviceIndex", childEndpointHexString)
private getEndpointCount() {
switch (model) {
case 'FNB56-ZSW01LX2.0' : return 1
case 'FNB56-ZSW02LX2.0' : return 2
case 'FNB56-ZSW03LX2.0' : return 3
case 'FB56+ZSW1GKJ2.5' : return 1
case 'FB56+ZSW1HKJ2.5' : return 2
case 'FB56+ZSW1IKJ2.5' : return 3
case 'FB56+ZSW1GKJ2.7' : return 1
case 'FB56+ZSW1HKJ2.7' : return 2
case 'FB56+ZSW1IKJ2.7' : return 3
case 'LXN-1S27LX1.0' : return 1
case 'LXN-2S27LX1.0' : return 2
case 'LXN-3S27LX1.0' : return 3
default : return 0
private void createChildDevices() {
log.debug("createChildDevices of $device.deviceNetworkId")
def endpointInt = zigbee.convertHexToInt(endpointId)
for (i in 1..endpointCount - 1) {
def endpointHexString = zigbee.convertToHexString(endpointInt + i, 2).toUpperCase()
createChildDevice("$deviceLabel${i + 1}", endpointHexString)
private void createChildDevice(String deviceLabel, String endpointHexString) {
it.deviceNetworkId == "$device.deviceNetworkId:$endpointHexString"
if (!childDevice) {
log.debug("Need to createChildDevice: $device.deviceNetworkId:$endpointHexString")
addChildDevice("smartthings", "Child Switch Health", "$device.deviceNetworkId:$endpointHexString", device.hubId,
[completedSetup: true, label: deviceLabel, isComponent: false])
} else {
log.debug("createChildDevice: SKIP - $device.deviceNetworkId:${endpointHexString}")
private getChildEndpoint(String dni) {
dni.split(":")[-1] as String
def on() {
log.debug("on")
zigbee.on()
def off() {
log.debug("off")
zigbee.off()
def childOn(String dni) {
log.debug("child on ${dni}")
def childEndpoint = getChildEndpoint(dni)
def endpointInt = zigbee.convertHexToInt(childEndpoint)
zigbee.command(zigbee.ONOFF_CLUSTER, 0x01, "", [destEndpoint: endpointInt])
def childOff(String dni) {
log.debug("child off ${dni}")
zigbee.command(zigbee.ONOFF_CLUSTER, 0x00, "", [destEndpoint: endpointInt])
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
return refresh()
def refresh() {
def cmds = zigbee.onOffRefresh()
cmds += zigbee.readAttribute(zigbee.ONOFF_CLUSTER, 0x0000, [destEndpoint: endpointInt + i])
} else {
cmds += zigbee.readAttribute(zigbee.ONOFF_CLUSTER, 0x0000, [destEndpoint: 0xFF])
return cmds
def poll() {
refresh()
def healthPoll() {
log.debug "healthPoll()"
def cmds = refresh()
cmds.each { sendHubCommand(new hubitat.device.HubAction(it)) }
def configureHealthCheck() {
Integer hcIntervalMinutes = 12
if (!state.hasConfiguredHealthCheck) {
log.debug "Configuring Health Check, Reporting"
unschedule("healthPoll")
runEvery5Minutes("healthPoll")
def healthEvent = [name: "checkInterval", value: hcIntervalMinutes * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID]]
// Device-Watch allows 2 check-in misses from device
sendEvent(healthEvent)
childDevices.each {
it.sendEvent(healthEvent)
state.hasConfiguredHealthCheck = true
def configure() {
log.debug "configure()"
// configureHealthCheck()
//other devices supported by this DTH in the future
def cmds = zigbee.onOffConfig(0, 120)
cmds += zigbee.configureReporting(zigbee.ONOFF_CLUSTER, 0x0000, 0x10, 0, 120, null, [destEndpoint: endpointInt + i])
} else {
cmds += zigbee.configureReporting(zigbee.ONOFF_CLUSTER, 0x0000, 0x10, 0, 120, null, [destEndpoint: 0xFF])
cmds += refresh()
return cmds
Thank you, solved my problem.
I have the driver for the version with physical buttons
A friend of mine made this script in Tamper Monkey that can generate a map of the ZigBee network on Smartthings, I know it is a very laborious thing to do but I didn't find anything like that in Hubitat. I'll leave it here so that if anyone wants to get inspired and do something similar or adapt the code it would be very interesting.
Hi all (and with a particular shout-out to @ogiewon, @mike.maxwell, @bcopeland, @bravenel, and @bobbyD),
After living for way too long on a hybrid Smartthings/Hubitat network, I've finally made a start on porting my Device-Type Handler and SmartApp for the Leviton VRCZ4-M04 Zone Controller. I have it half-working now, and wondered if I might run a couple of remaining issues by you all (with apologies if I've missed any relevant bits that are already posted to this thread and/or in docs.hubitat.com, though I haven't found any as yet)?
These are:
Dimming is only working in one direction (down), because the zwave command 133.4 Switch Multilevel Start Level Change is parsing differently in HE vs ST. Specifically,
zwave.parse('zw device: 03, command: 2604, payload: 40 00 ')
parses into this cmd on Smartthings:
SwitchMultilevelStartLevelChange(ignoreStartLevel: false, reserved00: 0, startLevel: 0, dimmingDuration: null, stepSize: null, upDown: 1, incDec: 0)
but parses on Hubitat as:
SwitchMultilevelStartLevelChange(dimmingDuration:null, ignoreStartLevel:null, incDec:null, startLevel:null, stepSize:null, upDown:null)
It does seem odd that I get some valid field values on ST, while the all-null field list on HE at least matches both docs.hubitat.com:
Command: 0x04
class hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelStartLevelChange {
Short dimmingDuration
Boolean ignoreStartLevel
Short incDec
Short startLevel
Short stepSize
Boolean upDown
List<Short> getPayload()
String format()
...and https://graph.api.smartthings.com/ide/doc/zwave-utils.html#switchMultilevelV3:
class physicalgraph.zwave.commands.switchmultilevelv3.SwitchMultilevelStartLevelChange
Short incDec
Short startLevel
Short stepSize
Short upDown
List<Short> payload
Short INC_DEC_INCREMENT = 0
Short UP_DOWN_UP = 0
Short INC_DEC_DECREMENT = 1
Short UP_DOWN_DOWN = 1
Short UP_DOWN_RESERVED2 = 2
Short INC_DEC_RESERVED2 = 2
Short UP_DOWN_NONE = 3
Short INC_DEC_NONE = 3
String format()
All I really need here is the upDown value, which is unfortunately null (like all the other values) on HE. Happy to provide the HE versions of my code (so far) if that helps?
Controlling the LEDs in the switches on the VRCZ4 is not working on HE -- this works on ST using some "black box" code inherited from ygelfand (see [OBSOLETE] Leviton VRCS4 - #90 by ygelfand - Community Created Device Types - SmartThings Community), to wit:
def setLightStatus(one,two,three,four) { def hidden = ["0F", "00", "13", device.deviceNetworkId ] def start = ["91", "00", "1D", "0D", "01", "FF"] def end = ["00", "00", "0A"] def light = integer(one) + (integer(two) << 1) + (integer(three) << 2) + (integer(four) << 3) log.debug "Setting button-light statuses for ${device.displayName}..." log.debug "one,two,three,four = $one,$two,$three,$four" log.debug "HIDDEN: $hidden" log.debug "START: $start" log.debug "END: $end" log.debug "LIGHT: $light" def checksum = 255 hidden.each { checksum^=(integerhex(it)) } log.debug "checksum, post-hidden: $checksum" start.each { checksum^=(integerhex(it)) } log.debug "checksum, post-start: $checksum" end.each { checksum^=(integerhex(it)) } log.debug "checksum, post-end: $checksum" checksum^=light log.debug "checksum, post-light: $checksum" log.debug "${start.join()}${String.format("%02X",light)}${end.join()}${String.format("%02X",checksum)}" sendHubCommand(new hubitat.device.HubAction("${start.join()}${String.format("%02X",light)}${end.join()}${String.format("%02X",checksum)}")) }
I know there was some early discussion of sendHubCommand() not working for devices, but I think that's since been remedied? I did also try just "returning" the new hubitat.device.HubAction() at the end instead (both with and without an explicit "return" keyword), to no effect.
IIRC, even ygelfand had inherited this code, which relied on some hackery to arrive at the construction of that command (since Leviton remains maddeningly proprietary and non-cooperative). But I can't see why the same HubAction() value that works when coming from ST
wouldn't work when coming from HE?
In any case, I'd greatly appreciate any insights, suggestions, and/or pointers to relevant HE threads/docs. Thanks in advance...
Regarding my second issue, I just noticed that the hub is generating log entries like so:
[sys:1] warn Unable to execute hubAction:91001D0D01FFFF00000A6A sent from Entrance 4-Button South, invalid or unspecified protocol
So it would seem that the HE hub is missing something here that the ST hub is understanding?
For the first issue, parse the switch multilevel class as v1, zwave.parse(description,[0x26])
For the second specify the protocol for the hub action by adding this to the hubAction call:
',hubitat.device.Protocol.ZWAVE'
Wow, amazing...done and done. Many thanks, Mike!
I'll likely make further tweaks to the dimming response, but my app/driver are fully functional now - probably time to post the code.
I found @bobbyD's thread Custom Device Drivers [Wiki], which led me to @csteele's thread Inventory of User Device Drivers? - #8 by csteele, which took me to HubitatCommunity ยท GitHub. I see in GitHub - HubitatCommunity/HubitatPublic that:
...you need to be a Member first. Therefore, to add a repository, contact csteele-PD (c steele) ยท GitHub. Repositories can be anything from a Readme pointing to your personal site to a multi-contributor, versioned driver or app! For more information, check out the forums at: https://community.hubitat.com/
I'll drop a direct message to @csteele straight away...
For the future... if any developer wants access, I really just need to know your Github ID to send an invite to the right person PM me your GitHub ID and I'll send an Invite.
Thanks, @csteele -- I've put the Leviton VRCZ4-M04 Zone Controller App and Driver up on my personal github site, with an intermediate Readme pointer at GitHub - HubitatCommunity/mpk: Hubitat Elevation Apps and Drivers.
Let me know (@bobbyD?) if/how I should update Community Apps, Community Device Drivers (AKA Compatible Devices Wiki), or any other listings? Looks like it's de rigueur to point from these lists to a new [RELEASE] topic in category Apps and Drivers > Community Apps (or Community Drivers), or Developers > Code Share (with tag community_app or community_driver)? Also unsure which category would be most appropriate under the Apps list?
I'm porting over a ST app and having trouble, what's the hubitat equivalent of this ST URL?
def redirectUrl = "https://graph.api.smartthings.com/oauth/initialize?appId=${app.id}&access_token=${atomicState.accessToken}&apiServerUrl=${getApiServerUrl()}"
Here's the app I'm porting:
Take a look at this package for the Honeywell Lyric and T-series thermostats. It's using the same Honeywell API as the leak sensors. It should answer any questions you might have:
Not a lot of luck here. I was able to get the new app built over at the development section of Honeywell. Copied the codes from there into the HUbitat app. Logged in to y account, picked the water sensors. Clicked done, hit the discovery button on the app...nothing. Tried the discovery button on the regular devices...Nothing
How does the "capability geolocation" from dth's translate in Hubitat?
capability "Switch"
capability "Lock"
capability "Power Meter"
capability "Sensor"
capability "Geolocation"
Not that I've been able to find.
I didn't use my words very well.
I meant that I don't think that capability, or any equivalent, exists in hubitat.
