Apostrophe Standardization
@bravenel @patrick I have noticed that apostrophe's entered via computer keyboard versus iOS device differ when setting a label on a device. This impacts the sort order of devices when viewing the list.
This would be ’ (typographic/slanted) vs ' (typewriter/straight)
Would it be possible to have the HE firmware standardize on one upon save?
For a base reference: ASCII and Unicode quotation marks
You want the U+2018 and U+2019 (aka curly/fancy quotes) to be converted to U+0027 the standard straight quote?
Not the grave accent U+0060 which is typically the key shared with "tilde" on a US keyboard.
A slanted quote aka grave accent is typically not considered the same as a single quote.
Correct or really a way to prevent the device list sort from being impacted by the apostrophe's. Thank you for the consideration!
This is a setting on your device.
In iOS
Settings > General > Keyboard > Disable Smart Punctuation
In MacOS
System Preferences > Keyboard > Text > Uncheck Smart Quotes and Dashes
I noticed the same thing a while ago, but IIRC there was a recent thread in which @patrick mentioned that special characters, including apostrophes, should be avoided?
