When running on mains and fully charged. When it's on battery I have bigger worries than hum
So this driver is basically a fork from another driver I found that was for APC devices. I think that driver used the Event Ghost functionality for some stuff with a windows pc. For the purpose of my use I just tweaked it to have commands that Node-Red could call to put information into HE. Event Ghost wasn't used at all for what I setup. Thinking back on it now I wish I remembered where i got the initial code from to give them credit.
*** I did find the Original Source which was device driver "Smart UPS apcupsd Monitor Device" originally written by Steven White and tweaked by Arn Burkhoff before i forked it for this virtual driver
Used them before here in the States and maybe its just old ears but never heard a hum - heard the running on battery indicator really well though (can be silenced).
Received the two UPS' today. Definitely silent while charging. Will plug a few things in either tonight or tomorrow and let you know if I hear anything.
My Eaton and APC UPSβs donβt make any noise either, unless they are charging after an outage. Then there is some minor fan noise but nothing else.
I have plugged one of the UPS' into my Study setup, including two laptops, a network switch, Sonos Speaker, 32" TV and few other bits and pieces. When running off main I think what I can hear is the same as @dJOS, a very, very faint hum of a fan. I have it sitting on my desk right next to me, but I would expect if I placed it further away I would not notice it at all unless there was dead silence in the room.
I'd forgotten we had discussed the driver options here as well....
I installed Arn Burkoff's version and have seen the stats coming through. I still need to finish the setup with EventGhost to send the stats through periodically. The UPS I have played with is plugged into my laptop at the moment, so went this route as it is running Windows. The UPS I plan to setup in my Living Room will most likely plug into a rpi, so I'll look at your suggestion around Node RED there.
I'd also add I have noticed a plastic-like smell that I had read about in a review (I think on Amazon) after having the UPS plugged in overnight, I assume once it had warmed up. Hopefully that will clear eventually....
How big is the ups?
Will they fit in a rack enclosure?
The model I bought, BX950MI-AZ, is designed to just sit on the floor. Its about 12cm(W) x 16cm(H) x 36cm(D).
At a glance it does look like APC and CyberPower do rack mount versions:
Thanks for that. After you made the thread I remembered that I had an APC Back UPS that I bought used quite a while ago and forgotten about. I plugged it in and it was dead silent!
Have looked at rack mount before and have always baulked at the prices!
Your one could sit nicely on a shelf still in the rack or even on too actually!
Cheers
You could probably go smaller now that I think it through a little more. Without looking at the different products, 500W is a bit more than you might need for most IT / IOT situations. So also worth thinking about that too, but they were on special and in the sweet spot for what I was happy to spend.
I just went for a 390w CyberPower one and even it keeps the network and IOT stuff up for an hour. I'll probably up it to a higher one when I add Poe cameras or APs
if you can cancel it quick it's on amazon for $109
What is?
Sorry I thought you just only ordered the UPS
The CP one? Nah had it a while. Good price if it's 109 though.
yeh - I'm in 2 minds, already have 4 UPS's lol
I was getting a lot of short outages so I grabbed the CP one from Officeworks in a hurry and it's worked well. Good price even at rep. But 109 is great
