Anyone still using the OW-Server 1-Wire to Ethernet Server Drivers
Considering using this for temp/humidity sensors. Anyone still using it? If so, how's it working for you?
Which drivers are you referring to?
These ...
@user2164 - you should probably tag @ckamps to find out if their drivers still work with current platform versions.
Still works fine in my home. Pretty basic technology. Hence the lack of changes to the driver. Would be like trying to enhance a nail…
Thanks for the quick reply. Glad to hear that it's still working. Looks like I will be placing an order.
I wish the sensors were cheaper. The EDS temp/humidity sensor is $68 + shipping. Do you know of any that are less expensive? I will probably need three, so I'm over $300.
Mine runs fine
@ckamps Will your driver support the EDS temp/humidity/pressure/light sensor (OW-ENV-THPL)?
I placed an order for the OW-Server and the temp/humidity sensor, but the sensor is backordered with a two month lead time. EDS offered me the temp/humidity/pressure/light sensor for $10 over the price of the temp/humidity sensor.
I'm willing to accept their offer it that sensor will still work with your driver. I don't care if your driver can't do anything with the pressure/light data because it's of no value to me at this time. I just would like to make sure your driver will work with the temp/humidity data from that sensor.
