- deviceId: 9
- deviceType: 2
- manufacturer: 881
- inClusters: 0x5E,0x85,0x8E,0x59,0x55,0x86,0x72,0x5A,0x87,0x73,0x80,0x9F,0x30,0x70,0x71,0x31,0x84,0x6C,0x7A
- firmwareVersion: 1.01
- protocolVersion: 7.12
- hardwareVersion: 1
Turns out, the device only checks the humidity every fifteen minutes, so this is the fastest it can update. If you have the regular reporting set to something else, then it will update if the other parameters have changed after it's 15 minute check. This is according to aeotec support.
LOL. I really don't know who is making the technical decisions at aeotec....
Their devices are always SO CLOSE to being good (even if the price always sucks)... But then they have some weird arse quirk that makes them less attractive.
More testing done. That's me and the misses having a shower. Reference device is the cheap Tuya zigbee device with the display. Batteries now reporting 80% for both, which is worrying. Sent the humidity report to 1% for testing only.
70% battery now for both. 0.5degrees change for temp & 5% for humidity
How are you charting the results?
It is probably grafana with influxDB database backend. There are a few methods to get the data in influxDB.
- Smartapp Influxdb Logger
- Node red to Influx DB
