It definitely needs some TLC. I really wish it were a local solution. I'm really thinking to switch out for RM3's instead - much cheaper, but not as elegant a solution out of the box of course. I've asked Sensibo for help to properly support Hubitat and they just don't give a fig, that much is clear.
Yeah, I've done the same and been given the usual "we'll look into it", followed by silence.
I suspect they are simply happy to aim at customers who use their mobile apps and don't see home automation hubs as a priority (Echo's excepted).
If you're ok with node-red and homebridge, it looks like sensibo is well supported via plugins.
I've got HomeBridge already - I didnt realise Sensibo was supported - there's a ton of Plugins!
How do you see the Sensibo in HB from HE?
That's where node red comes in (for me anyway)
There are various HB HE plugins but as I've not tried them I'm not sure how they work. I use NR to link to HB devices (although I've still to do the sensibo one - I'll get round to it at some point) and then back to HE via maker API.
So as mentioned I'm not a Coder, but after having a squiz thru the Device code, it appears that every single time any value for any field changes, it refreshes them all via this chunk of code.
def generateStatusEvent() {
def temperature = device.currentValue("temperature").toDouble()
def humidity = device.currentValue("humidity").toDouble()
def targetTemperature = device.currentValue("targetTemperature").split(' ')[0].toDouble()
def fanLevel = device.currentValue("fanLevel")
def mode = device.currentValue("currentmode")
def on = device.currentValue("on")
def swing = device.currentValue("swing")
def ClimateReact = device.currentValue("Climate")
def error = device.currentValue("Error")
def statusTextmsg = ""
def sUnit = device.currentValue("temperatureUnit")
statusTextmsg = "${humidity}%"
sendEvent("name":"statusText", "value":statusTextmsg, "description":"", displayed: false, isStateChange: true)
I'm not certain but I think the main "update" check section is from Line 1463 to 1707
def parseEventData(Map results)
If I remove the call to generateStatusEvent ()
from the end of this big chunk and insert the event calls into the relevant section, it might only update the events when they change, instead of on each poll.
Nope, that wasnt it - a bit more digging reveals this section:
// parse events into attributes
displayDebugLog("Parsing '${description}'")
def name = null
def value = null
def msg = parseLanMessage(description)
def headersAsString = msg.header // => headers as a string
def headerMap = msg.headers // => headers as a Map
def body = msg.body // => request body as a string
def status = msg.status // => http status code of the response
def json = msg.json // => any JSON included in response body, as a data structure of lists and maps
def xml = msg.xml // => any XML included in response body, as a document tree structure
def data = msg.data // => either JSON or XML in response body (whichever is specified by content-type header in response)
It just blats the data into the attributes regardless of if they have changed.
Appreciate your efforts on it!
I think I know how to fix it, I’ll have another crack at it today.
Argh, I have to admit defeat - I simply can not find a way to prevent this crappy App/Driver from refreshing every variable, every time. I spent hours on it today and got nowhere.
Take a rest mate. Maybe one of the coders/developers here can eventually assist us. Agree it is kindofa crappy app from the perspective of hub load. I'm just gonna synchronise every 30 minutes now - really not ideal.
I see @bptworld posted above and he certainly knows his way around Groovy! Maybe he might take a look at it for us to see if the code can be improved, if it is asynchronous etc?
That would be nice as I really suck at programming.
Im changing mine to 5 min intervals for now.
Sorry, I stopped using this device over a year ago. Never could get it to work properly. Device would lock up and need to be unplugged and then plugged back in. Never worked when I needed it. It now sits in the draw of shame.
Ah OK, no problem. I have 10. They work fine (although sometimes quite slow) but they definitely put a load on the hub according to the logs/stats. Maybe one day Sensibo will wake up and look after their customers with a healthy device driver and local support (ok, ok, I know, unlikely but I can live in hope).
Where do you change that? Im gonna set mine as well. Got it working sort of... but none of my temp adjustments actually push to the device.
Under apps, go into Sensibo Integration and re-run the setup.
OK, I have done a fair amount of work in this driver / app combo. I really don't like the way that it performs what are essentially driver functions within the app so I did start out to rewrite it completely but ran out of time so I ended up refactoring and cleaning up the code quite considerably. It no longer performs multiple refreshes and will poll after sending API changes to the Sensibo service so that it can refresh the attributes in the hub. 2 days later and I have something that is more rock solid and doesn't flood the log file with useless crap every time some happens.
NOTE: I have withdrawn the Actuator capability and the Thermostat capability so if anybody has managed to get standard Thermostat functions to work with the old code they will all break - YOU HAVE BEEN WARNED!! The reason for this is that the Thermostat feature wasn't compatible with the modes available through Hubitat and I am not clever enough to work out how to reset the modes available - it was easier to withdraw the capability. Maybe somebody can help me with setting custom modes for Thermostats - reintroducing the feature is fairly straightforward if we can get it to work.
The best way to interact with your Sensibo devices is via Custom Actions. I have essentially coded my own version of Climate React using RM and much better logic than the 2 level option in the standard Sensibo Climate React feature. Early testing looks like it is working quite well.
Ok, now for the code.... Happy for you guys to test and report back. If the fixes are straight forward I'll implement. I'll post it in two subsequent posts because ther is a word limit on the forum that I just discoverd!
Have fun guys - I am not really a coder (at least not any more) so this has been quite a project for me but I have enjoyed it
App Code
* Sensibo Integration for Hubitat
* Copyright 2019 Bryan Li
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Date Comments
* 2019-04-27 Based on work by Eric Gosselin - Modified for Hubitat
* 2019-07-23 Merge robert1's logging changes
* 2021-02-11 Refactored and cleaned up code (Paul Hutton - VeloWulf)
definition(
name: "Sensibo Integration",
namespace: "joyfulhouse",
author: "Bryan Li",
description: "Connect your Sensibo Pod to Hubitat.",
category: "Green Living",
iconUrl: "", // empty string - not implemented in Hubitat
iconX2Url: "", // empty string - not implemented in Hubitat
iconX3Url: "", // empty string - not implemented in Hubitat
singleInstance: true)
appSetting "apikey"
appSetting "logLevel"
preferences {
page(name: "SelectAPIKey", title: "API Key", content: "setAPIKey", nextPage: "deviceList", install: false, uninstall: true)
page(name: "deviceList", title: "Sensibo", content:"SensiboPodList", install:true, uninstall: true)
page(name: "timePage")
page(name: "timePageEvent")
// Initial variable declarations
def getServerUrl() { return "https://home.sensibo.com" }
def getChildNamespace() { return "joyfulhouse" }
def getChildTypeName() { return "SensiboPod" }
def getapikey() { return apiKey }
def getPollRateMillis() { return 45 * 1000 }
def getCapabilitiesRateMillis() {return 60 * 1000 }
// Logging and Event management
// debug logging set by logLevel application preference
def debugLog() {
if (logLevel == "DEBUG")
return true
else
return false
def traceLog() {
if (logLevel == "TRACE")
return true
else
return false
def debugEvent(value, message) {
def results = [
value: value,
descriptionText: message,
displayDebugLog( "Generating AppDebug Event: ${results}")
if (debugLog() || traceLog()) {
sendEvent (results)
def pollHandler() {
displayTraceLog("pollHandler called")
//debugEvent ("in Poll() method.")
// Hit the Sensibo API for update on all the Pod
def PodList = getChildDevices()
// Report on pods being refreshed
displayDebugLog(PodList)
PodList.each {
displayDebugLog( "polling " + it.deviceNetworkId)
pollChildren(it.deviceNetworkId) }
state.sensibo.each {stat ->
def dni = stat.key
displayDebugLog( ("DNI = ${dni}"))
// debugEvent ("DNI = ${dni}")
def d = getChildDevice(dni)
if(d) {
displayDebugLog( ("Found Child Device."))
// debugEvent ("Found Child Device.")
// debugEvent("Event Data before generate event call = ${stat}")
displayDebugLog( state.sensibo[dni])
// d.generateEvent(state.sensibo[dni].data)
// Integration version - not currently used
public static String version() { return "Hubitat" }
// Output log messages
private def displayDebugLog(message) {
if (debugLog() == true) log.debug "${message}"
if (traceLog() == true) log.trace "${message}"
private def displayTraceLog(message) {
// Capture APIkey and logging preference
def setAPIKey() {
displayTraceLog( "setAPIKey()")
if(appSettings)
def keystring = appSettings.apikey
else {
def keystring = ""
def p = dynamicPage(name: "SelectAPIKey", title: "Enter your API Key", uninstall: true) {
section("API Key"){
paragraph "Please enter your API Key provided by Sensibo \n\nAvailable at: \nhttps://home.sensibo.com/me/api"
input(name: "apiKey", title:"", type: "text", required:true, multiple:false, description: "", defaultValue: keystring)
section("Logging"){
paragraph "Application Logging Level"
input(name: "logLevel", type: "enum", title: "Logging Level", required:true, multiple:false, options: ["NONE","DEBUG","TRACE"], defaultValue: "NONE")
return p
def SensiboPodList()
displayTraceLog( "SensiboPodList()")
displayDebugLog( apiKey )
def stats = getSensiboPodList()
// displayDebugLog( "device list: $stats")
def p = dynamicPage(name: "deviceList", title: "Select Your Sensibo Pod", uninstall: true) {
section(""){
paragraph "Tap below to see the list of Sensibo Pods available in your Sensibo account and select the ones you want to connect to Hubitat."
input(name: "SelectedSensiboPods", title:"Pods", type: "enum", required:true, multiple:true, description: "Tap to choose", options: stats)
section("Refresh") {
input(name:"refreshinminutes", title: "Refresh rates in minutes", type: "enum", required:false, multiple: false, options: ["1", "5", "10","15","30"])
return p
def getSensiboPodList()
displayTraceLog( "getSensiboPodList called")
def deviceListParams = [
uri: "${getServerUrl()}",
path: "/api/v2/users/me/pods",
requestContentType: "application/json",
// query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json",fields:"id,room" ]]
query: [apiKey:apiKey, type:"json",fields:"id,room" ]]
def pods = [:]
try {
httpGet(deviceListParams) { resp ->
if(resp.status == 200) {
resp.data.result.each { pod ->
def key = pod.id
def value = pod.room.name
pods[key] = value
state.pods = pods
catch(Exception e) {
displayDebugLog( "Exception Get Json: " + e)
// debugEvent ("Exception get JSON: " + e)
displayDebugLog( "Sensibo Pods: $pods" )
return pods
// Function that runs when the app is first installed
def installed() {
displayTraceLog( "Installed() called with settings: ${settings}")
// state.lastTemperaturePush = null
// state.lastHumidityPush = null
initialize()
/*def d = getChildDevices() // Can't find that this actually does anything - probably remove (d is returned by the initiatize function and is then overwritten by this definition
if (boolnotifevery) {
//runEvery1Hour("hournotification")
schedule("0 0 * * * ?", "hournotification")
displayDebugLog( "Configured health checkInterval when installed()")
sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: true)*/
//subscribe(d,"temperatureUnit",eTempUnitHandler)
/*if (sendPushNotif) {
subscribe(d, "temperature", eTemperatureHandler)
subscribe(d, "humidity", eHumidityHandler)
}*/ // Can't find the sendPushNotif variable anywhere - probably remove code
// Function that runs when the app is updated
def updated() {
displayTraceLog( "Updated() called with settings: ${settings}")
unschedule() // Remove any scheduled tasks. If method is called without parameters, all schedules will be removed.
// unsubscribe() // Unsubscribe from events sent from a device or all event subscriptions.
initialize()
// Function that runs when the app is removed (uninstalled)
def uninstalled() {
// Needs code
displayTraceLog ( "Uninstalled called with settings: ${settings}")
def ping() {
displayTraceLog( "ping called")
def returnStatus = true
try {
returnStatus = true
catch(Exception e)
returnStatus = false
return returnStatus
def hournotification() {
displayTraceLog( "hournotification() called")
def hour = new Date()
def curHour = hour.format("HH:mm",location.timeZone)
def curDay = hour.format("EEEE",location.timeZone)
// Check the time Threshold
def stext = ""
if (startTimeEvent && endTimeEvent) {
def minHour = new Date().parse(smartThingsDateFormat(), startTimeEvent)
def endHour = new Date().parse(smartThingsDateFormat(), endTimeEvent)
def minHourstr = minHour.format("HH:mm",location.timeZone)
def maxHourstr = endHour.format("HH:mm",location.timeZone)
if (curHour >= minHourstr && curHour <= maxHourstr)
def devices = getChildDevices()
devices.each { d ->
displayTraceLog( "Notification every hour for device: ${d.id}")
def currentPod = d.displayName
def currentTemperature = d.currentState("temperature").value
def currentHumidity = d.currentState("humidity").value
def currentBattery = d.currentState("voltage").value
def sunit = d.currentState("temperatureUnit").value
stext = "${currentPod} - Temperature: ${currentTemperature} ${sunit} Humidity: ${currentHumidity}% Battery: ${currentBattery}"
sendPush(stext)
else {
devices.each { d ->
sendPush(stext)
//def switchesHandler(evt)
// if (evt.value == "on") {
// displayDebugLog( "switch turned on!")
// } else if (evt.value == "off") {
// displayDebugLog( "switch turned off!")
def eTempUnitHandler(evt)
//refreshOneDevice(evt.device.displayName)
def eTemperatureHandler(evt){
def currentTemperature = evt.device.currentState("temperature").value
def currentPod = evt.device.displayName
if (inDateThreshold(evt,"temperature") == true) {
if(maxTemperature != null){
if(currentTemperature.toDouble() > maxTemperature)
def stext = "Temperature level is too high at ${currentPod} : ${currentTemperature}"
sendEvent(name: "lastTemperaturePush", value: "${stext}", displayed : "true", descriptionText:"${stext}")
sendPush(stext)
state.lastTemperaturePush = hour
if(minTemperature != null) {
if(currentTemperature.toDouble() < minTemperature)
def stext = "Temperature level is too low at ${currentPod} : ${currentTemperature}"
sendPush(stext)
def eHumidityHandler(evt){
def currentHumidity = evt.device.currentState("humidity").value
if (inDateThreshold(evt,"humidity") == true) {
if(maxHumidity != null){
if(currentHumidity.toDouble() > maxHumidity)
def stext = "Humidity level is too high at ${currentPod} : ${currentHumidity}"
sendEvent(name: "lastHumidityPush", value: "${stext}", displayed : "true", descriptionText:"${stext}")
sendPush(stext)
state.lastHumidityPush = hour
if(minHumidity != null) {
if(currentHumidity.toDouble() < minHumidity)
def stext = "Humidity level is too low at ${currentPod} : ${currentHumidity}"
sendPush(stext)
public smartThingsDateFormat() { "yyyy-MM-dd'T'HH:mm:ss.SSSZ" }
public smartThingsDateFormatNoMilli() { "yyyy-MM-dd'T'HH:mm:ssZ" }
def canPushNotification(currentPod, hour,sType) {
// Check if the client already received a push
if (sType == "temperature") {
if (sfrequency.toString().isInteger()) {
if (state.lastTemperaturePush != null) {
long unxNow = hour.time
def before = new Date().parse(smartThingsDateFormatNoMilli(),state.lastTemperaturePush)
long unxEnd = before.time
unxNow = unxNow/1000
unxEnd = unxEnd/1000
def timeDiff = Math.abs(unxNow-unxEnd)
timeDiff = timeDiff/60
if (timeDiff <= sfrequency)
return false
else {
if (state.lastHumidityPush != null) {
def before = new Date().parse(smartThingsDateFormatNoMilli(),state.lastHumidityPush)
return false
return true
def inDateThreshold(evt,sType) {
def result = canPushNotification(currentPod,hour, sType)
if (!result) {
return false
// Check the day of the week
if (days != null && !days.contains(curDay)) {
return false
if (startTime && endTime) {
def minHour = new Date().parse(smartThingsDateFormat(), startTime)
def endHour = new Date().parse(smartThingsDateFormat(), endTime)
if (curHour >= minHourstr && curHour < maxHourstr)
return true
else
return false
return true
def refresh() {
displayTraceLog( "refresh() called with rate of " + refreshinminutes + " minutes")
unschedule()
refreshDevices()
if (refreshinminutes == "1")
runEvery1Minute("refreshDevices")
else if (refreshinminutes == "5")
runEvery5Minutes("refreshDevices")
else if (refreshinminutes == "10")
runEvery10Minutes("refreshDevices")
else if (refreshinminutes == "15")
runEvery15Minutes("refreshDevices")
else if (refreshinminutes == "30")
runEvery30Minutes("refreshDevices")
else
def refreshOneDevice(dni) {
displayTraceLog( "refreshOneDevice() called")
d.refresh()
def initialize() {
displayTraceLog( "initialize() called")
displayTraceLog( "key "+ getapikey())
state.apikey = getapikey()
def devices = SelectedSensiboPods.collect { dni ->
displayDebugLog("Initialising " + dni)
def d = getChildDevice(dni) // grab child devices with the current collection entry
if(!d) // the return is empty so no device exists in which case add it
def name = getSensiboPodList().find( {key,value -> key == dni })
displayDebugLog( "Pod : ${name.value} - Hub : ${location.hubs[0].name} - Type : " + getChildTypeName() + " - Namespace : " + getChildNamespace())
d = addChildDevice(getChildNamespace(), getChildTypeName(), dni, location.hubs[0].id, [
"label" : "${name.value} Pod",
"name" : "${name.value} Pod"
// d.setIcon("on","on","https://image.ibb.co/jgAMW8/sensibo-sky-off.png") // can't find eveidence that this does anything - probably remove
// d.setIcon("off","on","https://image.ibb.co/jgAMW8/sensibo-sky-off.png")
d.save()
displayTraceLog( "created ${d.displayName} with id $dni")
else { // Tell the user that the device already exists
displayTraceLog( "found ${d.displayName} with id $dni already exists")
return d
displayTraceLog( "created ${devices.size()} Sensibo Pod")
def delete
// Delete any that are no longer selected
if(!SelectedSensiboPods) {
displayDebugLog( "Removing all Sensibo devices")
delete = getChildDevices()
else {
delete = getChildDevices().findAll { !SelectedSensiboPods.contains(it.deviceNetworkId) }
displayTraceLog( "deleting ${delete.size()} Sensibo")
delete.each { deleteChildDevice(it.deviceNetworkId) }
// def PodList = getChildDevices()
pollHandler()
// refreshDevices() // devices are refreshed in pollhandler
//Set up schedule for refreshing devices based on app preferences
else
def refreshDevices() {
displayTraceLog( "refreshDevices() called")
devices.each { d ->
displayDebugLog( "Calling refresh() on device: ${d.id}")
d.refresh()
def pollChildren(PodUid) {
displayTraceLog( "pollChildren() called")
def thermostatIdsString = PodUid
displayTraceLog( "polling children: $thermostatIdsString")
def pollParams = [
path: "/api/v2/pods/${thermostatIdsString}/measurements",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"batteryVoltage,temperature,humidity,time"]]
// query: [apiKey:"${getapikey()}", type:"json", fields:"batteryVoltage,temperature,humidity,time"]]
// debugEvent ("Before HTTPGET to Sensibo.")
try {
httpGet(pollParams) { resp ->
if (resp.data) {
// debugEvent ("Response from Sensibo GET = ${resp.data}")
// debugEvent ("Response Status = ${resp.status}")
displayTraceLog( "poll results returned")
displayDebugLog( "DEBUG DATA RESULT" + resp.data.result)
if (resp.data.result == null || resp.data.result.empty) {
displayDebugLog( "Cannot get measurement from the API, should ask Sensibo Support Team")
// debugEvent ("Cannot get measurement from the API, should ask Sensibo Support Team",true)
def setTemp = getACState(thermostatIdsString)
def ClimateReact = getClimateReact(thermostatIdsString)
if (setTemp.Error != "Failed") {
state.sensibo = resp.data.result.inject([:]) { collector, stat ->
def dni = thermostatIdsString
displayDebugLog( "updating dni $dni")
def stemp = stat.temperature ? stat.temperature.toDouble().round(1) : 0
def shumidify = stat.humidity ? stat.humidity.toDouble().round() : 0
if (setTemp.temperatureUnit == "F") {
stemp = cToF(stemp).round(1)
def tMode
if (setTemp.on=="off") {
tMode = "off"
else {
tMode = setTemp.currentmode
def battpourcentage = 100
def battVoltage = stat.batteryVoltage
if (battVoltage == null) {
battVoltage = 3000
if (battVoltage < 2850) battpourcentage = 10
if (battVoltage > 2850 && battVoltage < 2950) battpourcentage = 50
def data = [
temperature: stemp,
humidity: shumidify,
targetTemperature: setTemp.targetTemperature,
fanLevel: setTemp.fanLevel,
currentmode: setTemp.currentmode,
on: setTemp.on,
switch : setTemp.on,
// thermostatMode: tMode,
// thermostatFanMode: setTemp.fanLevel,
// coolingSetpoint: setTemp.targetTemperature,
// heatingSetpoint: setTemp.targetTemperature,
// thermostatSetpoint: setTemp.targetTemperature,
temperatureUnit : setTemp.temperatureUnit,
voltage : battVoltage,
swing : setTemp.swing,
battery : battpourcentage,
powerSource : setTemp.powerSource,
productModel : setTemp.productModel,
firmwareVersion : setTemp.firmwareVersion,
Climate : ClimateReact.Climate,
Error: setTemp.Error
debugEvent ("pollChildren","Event Data = ${data}")
collector[dni] = [data:data]
return collector
displayDebugLog( "updated ${state.sensibo[thermostatIdsString].size()} stats: ${state.sensibo[thermostatIdsString]}")
debugEvent ("pollChildren","updated ${state.sensibo[thermostatIdsString]}")
else {
log.error "polling children & got http status ${resp.status}"
displayDebugLog( "___exception polling children: " + e)
// debugEvent ("pollChildren","${e}")
// Poll Child is invoked from the Child Device itself as part of the Poll Capability
def pollChild( child ) {
displayTraceLog( "pollChild() called")
//debugEvent ("poll child","poll child")
def now = new Date().time
debugEvent ("poll child","Last Poll Millis = ${state.lastPollMillis}")
def last = state.lastPollMillis ?: 0
def next = last + pollRateMillis
displayDebugLog( "pollChild( ${child.device.deviceNetworkId} ): $now > $next ?? w/ current state: ${state.sensibo}")
// debugEvent ("poll child","pollChild( ${child.device.deviceNetworkId} ): $now > $next ?? w/ current state: ${state.sensibo}")
//if( now > next ) {
if( true ) { // for now let's always poll/refresh
displayDebugLog( "polling children because $now > $next")
debugEvent("poll child","polling children because $now > $next")
pollChildren(child.device.deviceNetworkId)
displayDebugLog( "polled children and looking for ${child.device.deviceNetworkId} from ${state.sensibo}")
// debugEvent ("poll child","polled children and looking for ${child.device.deviceNetworkId} from ${state.sensibo}")
def currentTime = new Date().time
debugEvent ("poll child","Current Time = ${currentTime}")
state.lastPollMillis = currentTime
def tData = state.sensibo[child.device.deviceNetworkId]
if (tData == null) return
displayDebugLog("DEBUG - TDATA" + tData)
//debugEvent ("poll child","Error in Poll ${tData.data.Error}")
//tData.Error = false
//tData.data.Error = "Failed"
if(tData.data.Error != "Success") {
log.error "ERROR: Device connection removed? no data for ${child.device.deviceNetworkId} after polling"
// TODO: flag device as in error state
// child.errorState = true
return null
tData.updated = currentTime
return tData.data
else if(state.sensibo[child.device.deviceNetworkId] != null) {
displayDebugLog( "not polling children, found child ${child.device.deviceNetworkId} ")
if(!tData.updated) {
// we have pulled new data for this thermostat, but it has not asked us for it
// track it and return the data
tData.updated = new Date().time
return tData.data
return null
else if(state.sensibo[child.device.deviceNetworkId] == null) {
log.error "ERROR: Device connection removed? no data for ${child.device.deviceNetworkId}"
return null
else {
// it's not time to poll again and this thermostat already has its latest values
return null
def configureClimateReact(child,String PodUid,String JsonString)
displayTraceLog( "configureClimateReact() called for $PodUid with settings : $JsonString" )
def result = sendPostJsonClimate(PodUid, JsonString)
if (result) {
if (tData == null) {
//tData.data.Climate = ClimateState
tData.data.Error = "Success"
else {
if (tData == null) return false
return(result)
def setClimateReact(child,String PodUid, ClimateState) {
displayTraceLog( "setClimateReact() called for $PodUid Climate React: $ClimateState" )
def ClimateReact = getClimateReact(PodUid)
displayDebugLog( "DEBUG " + ClimateReact.Climate + " " + ClimateState)
if (ClimateReact.Climate == "notdefined") {
tData.data.Climate = ClimateReact.Climate
return true
def jsonRequestBody
if (ClimateState == "on") {
jsonRequestBody = '{"enabled": true}'
else {
jsonRequestBody = '{"enabled": false}'
displayDebugLog( "Mode Request Body = ${jsonRequestBody}")
def result = sendPutJson(PodUid, jsonRequestBody)
if (result) {
else {
return(result)
def setACStates(child,String PodUid, on, mode, targetTemperature, fanLevel, swingM, sUnit) {
displayTraceLog( "setACStates() called for $PodUid ON: $on - MODE: $mode - Temp : $targetTemperature - FAN : $fanLevel - SWING MODE : $swingM - UNIT : $sUnit")
//Return false if no values was read from Sensibo API
if (on == "--") { return false }
def OnOff = (on == "on") ? true : false
//if (swingM == null) swingM = "stopped"
displayTraceLog( "Target Temperature :" + targetTemperature)
def jsonRequestBody = '{"acState":{"on": ' + OnOff.toString() + ',"mode": "' + mode + '"'
displayDebugLog( "Fan Level is :$fanLevel")
displayDebugLog( "Swing is :$swingM")
displayDebugLog( "Target Temperature is :$targetTemperature")
if (fanLevel != null) {
displayDebugLog( "Fan Level info is present")
jsonRequestBody += ',"fanLevel": "' + fanLevel + '"'
if (targetTemperature != 0) {
jsonRequestBody += ',"targetTemperature": '+ targetTemperature + ',"temperatureUnit": "' + sUnit + '"'
if (swingM)
jsonRequestBody += ',"swing": "' + swingM + '"'
jsonRequestBody += '}}'
debugEvent ("setACStates","Mode Request Body = ${jsonRequestBody}")
boolean result = true
if(!sendJson(PodUid, jsonRequestBody)) {
result = false
if (result) {
displayDebugLog( "Device : " + child.device.deviceNetworkId + " state : " + tData)
tData.data.fanLevel = fanLevel
// tData.data.thermostatFanMode = fanLevel
// tData.data.on = on
tData.data.currentmode = mode
displayDebugLog( "Thermostat mode " + on)
/*if (on=="off") {
tData.data.thermostatMode = "off"
else {
tData.data.thermostatMode = mode
tData.data.targetTemperature = targetTemperature
// tData.data.coolingSetpoint = targetTemperature
// tData.data.heatingSetpoint = targetTemperature
// tData.data.thermostatSetpoint = targetTemperature
tData.data.temperatureUnit = sUnit
tData.data.swing = swingM
else {
return(result)
//Get the capabilities of the A/C Unit
def getCapabilities(PodUid, mode) {
displayTraceLog( "getCapabilities() called")
def last = state.lastPollCapabilitiesMillis ?: 0
def next = last + getCapabilitiesRateMillis()
def data = [:]
if (state.capabilities == null || state.capabilities.$PodUid == null || now > next) {
//if (true) {
displayDebugLog( "Now : " + now + " Next : " + next )
//def data = [:]
def pollParams = [
path: "/api/v2/pods/${PodUid}",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"remoteCapabilities,productModel"]]
try {
displayTraceLog( "getCapabilities() called - Request sent to Sensibo API(remoteCapabilities) for PODUid : $PodUid")
if (resp.data) {
displayDebugLog( "Status : " + resp.status)
//resp.data = [result: [remoteCapabilities: [modes: [heat: [swing: ["stopped", "fixedTop", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: [C: ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "medium", "high", "auto"]], fan: [swing: ["stopped", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: [C: ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "medium", "high", "auto"]], cool: [swing: ["stopped", "fixedTop", "fixedMiddleTop", "fixedMiddle", "fixedMiddleBottom", "fixedBottom", "rangeTop", "rangeMiddle", "rangeBottom", "rangeFull"], temperatures: ["C": ["isNative": true, "values": [16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], F: ["isNative": false, "values": [61, 63, 64, 66, 68, 70, 72, 73, 75, 77, 79, 81, 82, 84, 86]]], fanLevels: ["low", "high", "auto"]]]]]]
//resp.data = ["result": ["productModel": "skyv2", "remoteCapabilities": ["modes": ["dry": ["temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "swing": ["stopped", "rangeFull"]], "auto": ["temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "swing": ["stopped", "rangeFull"]], "heat": ["swing": ["stopped", "rangeFull"], "temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "fanLevels": ["low", "medium", "high", "auto"]], "fan": ["swing": ["stopped", "rangeFull"], "temperatures": [], "fanLevels": ["low", "medium", "high", "auto"]], "cool": ["swing": ["stopped", "rangeFull"], "temperatures": ["C": ["isNative": false, "values": [17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]], "F": ["isNative": true, "values": [62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86]]], "fanLevels": ["low", "medium", "high", "auto"]]]]]]
displayDebugLog( resp.data)
if (state.capabilities == null) { state.capabilities = [:] }
state.capabilities.$PodUid = resp.data
displayDebugLog( "Successfull read from Sensibo")
displayTraceLog( "Capabilities from Sensibo for ${PodUid} : " + state.capabilities.$PodUid)
debugEvent ("getCapabilities","Current Time = ${currentTime}")
state.lastPollCapabilitiesMillis = currentTime
switch (mode){
case "dry":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.dry,
productModel : resp.data.result.productModel
break
case "cool":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.cool,
break
case "heat":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.heat,
break
case "fan":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.fan,
break
case "auto":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes.auto,
break
case "modes":
data = [
remoteCapabilities : resp.data.result.remoteCapabilities.modes,
break
displayTraceLog( "Returning remoteCapabilities from Sensibo")
return data
else {
displayDebugLog( "get remoteCapabilities Failed")
data = [
remoteCapabilities : "",
productModel : ""
return data
return data
displayDebugLog( "get remoteCapabilities Failed" + e)
data = [
productModel : ""
return data
else {
displayTraceLog( "Capabilities from local for ${PodUid} : " + state.capabilities.$PodUid)
//return
switch (mode){
case "dry":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.dry,
productModel : state.capabilities.$PodUid.result.productModel
break
case "cool":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.cool,
break
case "heat":
data = [
remoteCapabilities :state.capabilities.$PodUid.result.remoteCapabilities.modes.heat,
break
case "fan":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.fan,
break
case "auto":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes.auto,
break
case "modes":
data = [
remoteCapabilities : state.capabilities.$PodUid.result.remoteCapabilities.modes,
break
displayTraceLog( "Returning remoteCapabilities from local")
return data
// Get Climate React settings
def getClimateReact(PodUid) {
displayTraceLog( "getClimateReact() called")
def data = [:]
def pollParams = [
path: "/api/v2/pods/${PodUid}/smartmode",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"*"]]
try {
/*if (resp.data) {
displayTraceLog( "Get ClimateReact " + resp.data.result)
if (!resp.data.result) {
data = [
Climate : "notdefined",
Error : "Success"
displayDebugLog( "Returning Climate React (not configured)")
return data
resp.data.result.any { stat ->
displayTraceLog( "get ClimateReact Success")
displayDebugLog( "PodUID : $PodUid : " + PodUid )
def OnOff = "off"
if (resp.data.result.enabled != null) {
OnOff = resp.data.result.enabled ? "on" : "off"
data = [
Climate : OnOff.toString(),
Error : "Success"
displayDebugLog( "Climate: ${data.Climate}")
displayTraceLog( "Returning Climate React" )
return data
else {
data = [
Error : "Failed"
displayDebugLog( "get ClimateReact Failed")
return data
return data
data = [
Error : "Failed"
return data
// Get the latest state from the Sensibo Pod
def getACState(PodUid) {
displayTraceLog( "getACState() called")
def data = [:]
def pollParams = [
path: "/api/v2/pods/${PodUid}/acStates",
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", limit:1, fields:"status,acState,device"]]
try {
/*if (resp.data) {
if (stat.status == "Success") {
displayTraceLog( "get ACState Success")
displayDebugLog( "PodUID : $PodUid : " + stat.acState)
def OnOff = stat.acState.on ? "on" : "off"
stat.acState.on = OnOff
def stemp
if (stat.acState.targetTemperature == null) {
stemp = stat.device.measurements.temperature.toInteger()
else {
stemp = stat.acState.targetTemperature.toInteger()
def tempUnit
if (stat.acState.temperatureUnit == null) {
tempUnit = stat.device.temperatureUnit
else {
tempUnit = stat.acState.temperatureUnit
def tMode
if (OnOff=="off") {
tMode = "off"
else {
tMode = stat.acState.mode
def sMode
if (stat.acState.swing == null) {
sMode = "stopped"
else {
sMode = stat.acState.swing
displayDebugLog( "product Model : " + stat.device.productModel)
def battery = stat.device.productModel == "skyv1" ? "battery" : "mains"
displayDebugLog( "swing Mode :" + stat.acState.swing)
data = [
targetTemperature : stemp,
fanLevel : stat.acState.fanLevel,
currentmode : stat.acState.mode,
on : OnOff.toString(),
switch: OnOff.toString(),
// thermostatFanMode : stat.acState.fanLevel,
// coolingSetpoint : stemp,
// heatingSetpoint : stemp,
// thermostatSetpoint : stemp,
temperatureUnit : tempUnit,
swing : sMode,
powerSource : battery,
productModel : stat.device.productModel,
firmwareVersion : stat.device.firmwareVersion,
Error : "Success"
displayDebugLog( "On: ${data.on} targetTemp: ${data.targetTemperature} fanLevel: ${data.fanLevel} swing: ${data.swing}")
displayTraceLog( "Returning ACState")
return data
else {
displayDebugLog( "get ACState Failed")
else {
data = [
targetTemperature : "0",
fanLevel : "--",
currentmode : "--",
on : "--",
switch : "--",
// thermostatMode: "--",
// thermostatFanMode : "--",
// coolingSetpoint : "0",
// heatingSetpoint : "0",
// thermostatSetpoint : "0",
temperatureUnit : "",
swing : "--",
powerSource : "",
productModel : "",
firmwareVersion : "",
Error : "Failed"
return data
return data
data = [
fanLevel : "--",
currentmode : "--",
on : "--",
switch : "--",
swing : "--",
powerSource : "",
productModel : "",
Error : "Failed"
return data
def sendPutJson(String PodUid, String jsonBody) {
displayTraceLog( "sendPutJson() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody")
def cmdParams = [
// headers: ["Content-Type": "application/json"],
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json"],
body: jsonBody]
try {
httpPut(cmdParams) { resp ->
displayDebugLog( "updated ${resp.data}")
// debugEvent("updated ${resp.data}")
displayTraceLog( "Successful call to Sensibo API.")
displayDebugLog( "Returning True")
return true
else {
displayTraceLog( "Failed call to Sensibo API.")
return false
displayDebugLog( "Exception Sending Json: " + e)
// debugEvent ("Exception Sending JSON: " + e)
return false
def sendPostJsonClimate(String PodUid, String jsonBody) {
displayTraceLog( "sendPostJsonClimate() called - Request sent to Sensibo API(smartmode) for PODUid : $PodUid - ${version()} - $jsonBody")
def cmdParams = [
body: jsonBody
try {
httpPost(cmdParams) { resp ->
//debugEvent("updated ${resp.data}")
return true
else {
return false
//debugEvent ("Exception Sending JSON: " + e)
return false
// Send state to the Sensibo Pod
def sendJson(String PodUid, String jsonBody) {
displayTraceLog( "sendJson() called - Request sent to Sensibo API(acStates) for PODUid : $PodUid - ${version()} - $jsonBody")
def cmdParams = [
query: [apiKey:"${getapikey()}", integration:"${version()}", type:"json", fields:"acState"],
body: jsonBody]
def returnStatus = false
try {
displayDebugLog("response status: ${resp.status}")
//returnStatus = resp.status
returnStatus = true
else {
displayDebugLog( "Return Status: ${returnStatus}")
return returnStatus
def cToF(temp) {
return (temp * 1.8 + 32).toDouble()
def fToC(temp) {
return ((temp - 32) / 1.8).toDouble()
// Subscribe functions
def OnOffHandler(evt) {
displayTraceLog( "on off handler activated")
debugEvent(evt.value)
//def name = evt.device.displayName
if (sendPush) {
//sendPush("The ${name} is turned on!")
//sendPush("The ${name} is turned off!")
Driver Code
* Sensibo Device Type Handler
* Date Comments
preferences {
//Logging Message Config
input name: "infoLogging", type: "bool", title: "Enable info message logging", description: ""
input name: "debugLogging", type: "bool", title: "Enable debug message logging", description: ""
input name: "traceLogging", type: "bool", title: "Enable trace message logging", description: ""
metadata {
definition (name: "SensiboPod", namespace: "joyfulhouse", author: "Bryan Li", oauth: false) {
// capability "Actuator"
capability "Battery"
capability "Health Check"
capability "Polling"
capability "PowerSource"
capability "Refresh"
capability "RelativeHumidityMeasurement"
capability "Sensor"
capability "Switch"
capability "TemperatureMeasurement"
// capability "Thermostat"
capability "Voltage Measurement"
attribute "swing", "String"
attribute "temperatureUnit","String"
attribute "productModel","String"
attribute "firmwareVersion","String"
attribute "Climate","String"
attribute "targetTemperature","Double"
attribute "statusText","String"
attribute "currentmode","String"
attribute "fanLevel","String"
//attribute "on","String" // Added by request of NateG
// command "setAll"
// command "switchFanLevel"
command "switchMode"
//command "raiseCoolSetpoint"
//command "lowerCoolSetpoint"
//command "raiseHeatSetpoint"
//command "lowerHeatSetpoint"
// command "voltage"
command "raiseTemperature"
command "lowerTemperature"
// command "switchSwing"
// command "modeSwing", [
// name:"Swing Mode", type: "ENUM", description: "Pick an option", constraints: [
// "fixedTop",
// "fixedMiddleTop",
// "fixedMiddle",
// "fixedMiddleBottom",
// "fixedBottom",
// "rangeTop",
// "rangeMiddle",
// "rangeBottom",
// "rangeFull",
// "horizontal",
// "both",
// "stopped"
// command "setThermostatMode"
command "modeHeat"
command "modeCool"
command "modeDry"
command "modeFan"
command "modeAuto"
command "lowFan"
command "mediumFan"
command "highFan"
command "quietFan"
command "strongFan"
// command "fullswing"
// command "setAirConditionerMode"
command "toggleClimateReact"
command "setCoolingSetpoint", ["number"]
command "setHeatingSetpoint", ["number"]
command "setClimateReact", [
name:"State", type: "ENUM", constraints: [
"on",
"off"
// command "configureClimateReact"
// determines the extent of the logging based upon device preferences
if (debugLogging) log.debug "${device.displayName}: ${message}"
if (traceLogging) log.trace "${device.displayName}: ${message}"
private def displayInfoLog(message) {
if (infoLogging || state.prefsSetCount != 1)
log.info "${device.displayName}: ${message}"
// Logging and event management
def generatefanLevelEvent(mode) {
sendEvent(name: "fanLevel", value: mode, descriptionText: "Fan mode is now ${mode}")
def generateModeEvent(mode) {
sendEvent(name: "Mode", value: mode, descriptionText: "AC mode is now ${mode}")
// def on = device.currentValue("on")
// sendEvent("name":"statusText", "value":statusTextmsg, "description":"")
def results = [
value: value,
displayDebugLog( "Generating DevDebug Event: ${results}")
sendEvent (results)
def generateErrorEvent() {
displayDebugLog("$device.displayName FAILED to set the AC State")
sendEvent(name: "Error", value: "Error", descriptionText: "$device.displayName FAILED to set or get the AC State", isStateChange: true)
def generateSetTempEvent(temp) {
sendEvent(name: "targetTemperature", value: temp, descriptionText: "$device.displayName set temperature is now ${temp}", isStateChange: true)
def generateSwitchEvent(mode) {
// sendEvent(name: "on", value: mode, descriptionText: "$device.displayName is now ${mode}", displayed: false, isStateChange: true)
sendEvent(name: "switch", value: mode, descriptionText: "$device.displayName is now ${mode}", isStateChange: true)
//refresh()
// Unit conversion
def fToc(temp) {
// AC Control functions start here
def switchMode() {
displayTraceLog( "switchMode() called")
def currentMode = device.currentState("currentmode")?.value
displayDebugLog("switching AC mode from current mode: $currentMode")
def returnCommand
switch (currentMode) {
case "heat":
returnCommand = modeMode("cool")
break
case "cool":
returnCommand = modeMode("fan")
break
case "fan":
returnCommand = modeMode("dry")
break
case "dry":
returnCommand = modeMode("auto")
break
case "auto":
returnCommand = modeMode("heat")
break
returnCommand
def modeMode(String newMode){
displayTraceLog( "modeMode() called with " + newMode)
def Setpoint = device.currentValue("targetTemperature").toInteger()
def LevelBefore = device.currentState("fanLevel").value
def capabilities = parent.getCapabilities(device.deviceNetworkId,newMode)
def Level = LevelBefore
if (capabilities.remoteCapabilities != null) {
def fanLevels = capabilities.remoteCapabilities.fanLevels
displayDebugLog("Fan levels capabilities : " + capabilities.remoteCapabilities.fanLevels)
Level = GetNextFanLevel(LevelBefore,capabilities.remoteCapabilities.fanLevels)
//displayDebugLog("Fan : " + Level)
def result = parent.setACStates(this, device.deviceNetworkId, "on", newMode, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Mode changed to " + newMode + " for " + device.deviceNetworkId)
if (LevelBefore != Level) {
generatefanLevelEvent(Level)
sendEvent(name: 'thermostatMode', value: newMode,isStateChange: true)
displayDebugLog("Current state: ${device.currentState("switch")}.value")
if (device.currentState("switch").value == "off") { generateSwitchEvent("on") }
generateModeEvent(newMode)
// generateStatusEvent()
refresh()
else {
else {
def themodes = parent.getCapabilities(device.deviceNetworkId,"modes")
def sMode = GetNextMode(newMode,themodes)
NextMode(sMode)
def GetNextFanLevel(fanLevel, fanLevels) {
displayTraceLog( "GetNextFanLevel called with " + fanLevel)
if (fanLevels == null || fanLevels == "null") {
return null
def listFanLevel = ['low','medium','high','auto','quiet','medium_high','medium_low','strong']
def newFanLevel = returnNext(listFanLevel,fanLevels,fanLevel)
displayDebugLog("Next fanLevel = " + newFanLevel)
return newFanLevel
def returnNext(liste1, liste2, val) throws Exception
try {
def index = liste2.indexOf(val)
if (index == -1) throw new Exception()
else return liste2[liste2.indexOf(val)]
if (liste1.indexOf(val)+ 1 == liste1.size()) {
val = liste1[0]
else {
val = liste1[liste1.indexOf(val) + 1]
def refresh() {
displayTraceLog( "refresh() called")
poll()
displayTraceLog( "refresh() ended")
void poll() {
displayTraceLog( "Executing 'poll' using parent SmartApp")
def results = parent.pollChild(this)
def linkText = getLinkText(device)
parseTempUnitEventData(results)
parseEventData(results)
def parseTempUnitEventData(Map results) {
displayDebugLog("parsing data $results")
if(results) {
results.each { name, value ->
if (name=="temperatureUnit") {
def isChange = true
sendEvent(
value: value,
//unit: value,
descriptionText: "${name} = ${value}",
handlerName: "temperatureUnit",
isStateChange: isChange,)
def parseEventData(Map results) {
displayDebugLog("parsing Event data $results")
if(results) {
displayDebugLog("name :" + name + " value :" + value)
def isChange = false
if (name=="voltage") {
isChange = true //isTemperatureStateChange(device, name, value.toString())
sendEvent(
value: value,
unit: "mA",
descriptionText: getThermostatDescriptionText(name, value, linkText),
handlerName: name,
isStateChange: isChange)
else if (name== "battery") {
sendEvent(
value: value,
//unit: "V",
handlerName: name,
else if (name== "powerSource") {
sendEvent(
value: value,
handlerName: name,
else if (name== "Climate") {
isChange = true
sendEvent(
value: value,
handlerName: name,
else if (name=="on") {
isChange = true
sendEvent(
value: value,
handlerName: name,
sendEvent(name: "switch", value: value)
/*else if (name=="thermostatMode") {
if (value=="cool") {
sendEvent(name: 'airConditionerMode', value: "cool",
sendEvent(name: 'thermostatOperatingState', value: "cooling",
else if (value=="heat") {
sendEvent(name: 'airConditionerMode', value: "heat",
sendEvent(name: 'thermostatOperatingState', value: "heating",
else if (value=="fan") {
sendEvent(name: 'airConditionerMode', value: "fanOnly",
sendEvent(name: 'thermostatOperatingState', value: "fan only",
else if (value=="dry") {
sendEvent(name: 'airConditionerMode', value: "dry",
sendEvent(name: 'thermostatOperatingState', value: "dry",
else if (value=="auto") {
sendEvent(name: 'airConditionerMode', value: "auto",
sendEvent(name: 'thermostatOperatingState', value: "auto",
else {
sendEvent(name: 'thermostatOperatingState', value: "idle",
sendEvent(
value: value,
handlerName: name,
else if (name=="coolingSetpoint" || name== "heatingSetpoint" || name == "thermostatSetpoint") {
sendEvent(
value: value,
//unit : device.currentValue("temperatureUnit"),
handlerName: name,
else if (name=="temperatureUnit") {
isChange = true
sendEvent(
value: value,
//unit: value,
handlerName: name,
/*else if (name=="thermostatFanMode") {
def mode = (value.toString() == "high" || value.toString() == "medium") ? "on" : value.toString()
mode = (mode == "low") ? "circulate" : mode
sendEvent(
value: value,
handlerName: name,
else if (name=="swing") {
sendEvent(
value: value,
handlerName: name,
else if (name=="temperature" || name== "lastTemperaturePush" || name== "lastHumidityPush") {
sendEvent(
value: value,
//unit: device.currentValue("temperatureUnit"),
handlerName: name,
else if (name=="humidity") {
sendEvent(
value: value,
handlerName: name,
else {
isChange = true//isStateChange(device, name, value.toString())
sendEvent(
value: value.toString(),
// linkText: linkText,
handlerName: name,
// generateStatusEvent ()
void raiseTemperature() {
displayTraceLog( "raiseTemperature() called" )
def operMode = device.currentState("currentmode").value
def theTemp = device.currentValue("temperatureUnit")
displayDebugLog("Current target temperature = ${Setpoint}")
Setpoint = temperatureUp(Setpoint)
if (Setpoint == -1) {
return
switch (operMode) {
case "heat":
setHeatingSetpoint(Setpoint)
break;
case "cool":
setCoolingSetpoint(Setpoint)
break;
case "fan":
setFanSetpoint(Setpoint)
break;
case "dry":
setDrySetpoint(Setpoint)
break;
case "auto":
break;
default:
break;
def temperatureUp(temp) {
displayTraceLog( "temperatureUp() called with "+ temp)
def sunit = device.currentValue("temperatureUnit")
def capabilities = parent.getCapabilities(device.deviceNetworkId, device.currentState("currentmode").value)
def values
if (sunit == "F") {
if (capabilities.remoteCapabilities.temperatures.F == null) {
return -1
values = capabilities.remoteCapabilities.temperatures.F.values
else {
if (capabilities.remoteCapabilities.temperatures.C == null) {
return -1
values = capabilities.remoteCapabilities.temperatures.C.values
def found = values.findAll{number -> number > temp}
displayDebugLog("Values retrieved : " + found)
if (found == null || found.empty) found = values.last()
else found = found.first()
displayDebugLog("Temp before : " + temp )
displayDebugLog("Temp after : " + found)
temp = found
return temp
// Set Temperature
def setHeatingSetpoint(temp) {
displayTraceLog( "setHeatingSetpoint() called")
temp = temp.toInteger()
displayDebugLog("setTemperature : " + temp)
def result = parent.setACStates(this, device.deviceNetworkId , "on", "heat", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Heating temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("heat")
//sendEvent(name: 'coolingSetpoint', value: temp, displayed: false)
sendEvent(name: 'heatingSetpoint', value: temp, displayed: false)
sendEvent(name: 'thermostatSetpoint', value: temp, displayed: false)
refresh()
else {
// Set Temperature
def setCoolingSetpoint(temp) {
displayTraceLog( "setCoolingSetpoint() called")
displayDebugLog("setTemperature : " + temp )
def result = parent.setACStates(this, device.deviceNetworkId , "on", "cool", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Cooling temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("cool")
//sendEvent(name: 'thermostatSetpoint', value: temp, displayed: false)
//sendEvent(name: 'heatingSetpoint', value: temp, displayed: false)
refresh()
else {
// Set Temperature
def setFanSetpoint(temp) {
displayTraceLog( "setFanSetpoint() called")
def result = parent.setACStates(this, device.deviceNetworkId , "on", "fan", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Fan temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("fan")
refresh()
else {
// Set Temperature
def setDrySetpoint(temp) {
displayTraceLog( "setDrySetpoint() called")
def result = parent.setACStates(this, device.deviceNetworkId , "on", "dry", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Dry temperature changed to " + temp + " for " + device.deviceNetworkId)
generateModeEvent("dry")
refresh()
else {
void lowerTemperature() {
displayTraceLog( "lowerTemperature() called")
Setpoint = temperatureDown(Setpoint)
return
switch (operMode) {
case "heat":
break;
case "cool":
break;
case "fan":
break;
case "dry":
break;
case "auto":
break;
default:
break;
def modeHeat() {
displayTraceLog( "modeHeat() called")
modeMode("heat")
def modeCool() {
displayTraceLog( "modeCool() called")
modeMode("cool")
def modeDry() {
displayTraceLog( "modeDry() called")
modeMode("dry")
def modeFan() {
displayTraceLog( "modeFan() called")
modeMode("fan")
def modeAuto() {
displayTraceLog( "modeAuto() called")
modeMode("auto")
def dfanLevel(String newLevel){
displayTraceLog( "dfanLevel called with fan = " + newLevel)
Level = GetNextFanLevel(newLevel,capabilities.remoteCapabilities.fanLevels)
def result = parent.setACStates(this, device.deviceNetworkId,"on", device.currentState("currentmode").value, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Fan level changed to " + Level + " for " + device.deviceNetworkId)
if (Level == "low") {
sendEvent(name: 'thermostatFanMode', value: "circulate", displayed: false)
else {
sendEvent(name: 'thermostatFanMode', value: "on", displayed: false)
refresh()
else {
else {
displayDebugLog ("Fan mode does not exist")
// other instructions may be required if mode does not exist
def lowFan() {
displayTraceLog( "lowfan() called")
dfanLevel("low")
def mediumFan() {
displayTraceLog( "mediumfan() called")
dfanLevel("medium")
def highFan() {
displayTraceLog( "highfan() called")
dfanLevel("high")
def quietFan() {
displayTraceLog( "quietfan() called")
dfanLevel("quiet")
def strongFan() {
displayTraceLog( "strongfan() called")
dfanLevel("strong")
def autoFan() {
displayTraceLog( "autofan() called")
dfanLevel("auto")
def setAll(newMode,temp,fan) {
displayTraceLog( "setAll() called with " + newMode + "," + temp + "," + fan )
def Setpoint = temp.toInteger()
def LevelBefore = fan
if (result) {
sendEvent(name: 'thermostatMode', value: newMode, displayed: false,isStateChange: true)
refresh()
else {
else {
def fullswing()
displayTraceLog( "fullswing() called")
modeSwing("rangeFull")
def temperatureDown(temp)
displayTraceLog( "temperatureDown() called with "+ temp)
def values
if (sunit == "F") {
return -1
else {
return -1
def found = values.findAll{number -> number < temp}
if (found == null || found.empty) found = values.first()
else found = found.last()
temp = found
return temp
void lowerCoolSetpoint() {
displayTraceLog( "lowerCoolSetpoint() called")
def result = parent.setACStates(this, device.deviceNetworkId , "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Cooling temperature changed to " + Setpoint + " for " + device.deviceNetworkId)
sendEvent(name: 'coolingSetpoint', value: Setpoint, displayed: false)
//sendEvent(name: 'thermostatSetpoint', value: Setpoint, displayed: false)
generateSetTempEvent(Setpoint)
displayDebugLog("New target Temperature = ${Setpoint}")
//generateStatusEvent()
refresh()
else {
displayDebugLog("error")
void setThermostatMode(modes) {
displayTraceLog( "setThermostatMode() called")
def currentMode = device.currentState("currentmode").value
switch (modes) {
case "cool":
modeCool()
break
//case "fan":
// returnCommand = modeFan()
// break
//case "dry":
// returnCommand = modeDry()
// break
case "auto":
modeAuto()
break
case "heat":
modeHeat()
break
case "off":
off()
break
void setAirConditionerMode(modes)
displayTraceLog( "setAirConditionerMode() called")
switch (modes) {
case "cool":
modeCool()
break
case "fanOnly":
case "fan":
modeFan()
break
case "dry":
modeDry()
break
case "auto":
modeAuto()
break
case "heat":
modeHeat()
break
void raiseCoolSetpoint() {
displayTraceLog( "raiseCoolSetpoint() called")
if (result) {
refresh()
else {
void raiseHeatSetpoint() {
displayTraceLog( "raiseHeatSetpoint() called")
if (result) {
displayInfoLog( "Heating temperature changed to " + Setpoint + " for " + device.deviceNetworkId)
sendEvent(name: 'heatingSetpoint', value: Setpoint, displayed: false)
refresh()
else {
void lowerHeatSetpoint() {
displayTraceLog( "lowerHeatSetpoint() called")
if (result) {
refresh()
else {
// Turn off or Turn on the AC
def on() {
displayTraceLog( "on called")
//def Setpoint = device.currentValue("targetTemperature").toInteger()
displayDebugLog("Temp Unit : " + device.currentState("temperatureUnit").value)
displayDebugLog("Temp Unit (Setpoint) : " + Setpoint)
def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
displayDebugLog("Result : " + result)
if (result) {
displayInfoLog( "AC turned ON for " + device.deviceNetworkId)
sendEvent(name: 'thermostatMode', value: device.currentState("currentmode").value,isStateChange: true)
//sendEvent(name: 'thermostatOperatingState', value: "idle",isStateChange: true)
refresh()
else {
def off() {
displayTraceLog( "off called")
def result = parent.setACStates(this, device.deviceNetworkId, "off", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "AC turned OFF for " + device.deviceNetworkId)
sendEvent(name: 'thermostatMode', value: "off", isStateChange: true)
generateSwitchEvent("off")
refresh()
else {
// toggle Climate React
def toggleClimateReact()
displayTraceLog( "toggleClimateReact() called")
def currentClimateMode = device.currentState("Climate")?.value
def returnCommand
switch (currentClimateMode) {
case "off":
returnCommand = setClimateReact("on")
break
case "on":
returnCommand = setClimateReact("off")
break
if (!returnCommand) { returnCommand }
// Set Climate React
def setClimateReact(ClimateState) {
/// Parameter ClimateState : "on" or "off"
displayTraceLog( "setClimateReact() called")
displayDebugLog("Climate : " + ClimateState )
def result = parent.setClimateReact(this, device.deviceNetworkId, ClimateState)
if (result) {
displayInfoLog( "Climate React changed to " + ClimateState + " for " + device.deviceNetworkId)
sendEvent(name: 'Climate', value: ClimateState, displayed: false)
//generateSetTempEvent(temp)
refresh()
else {
//refresh()
/* // Disabling this for the time being
def configureClimateReact(lowThres, highThres,stype,lowState,highState, on_off, ThresUnit)
// lowThres and highThres - Integer parameters
// stype : possible values are "temperature", "humidity" or "feelsLike"
// lowState and highState :
// on, fanLevel, temperatureUnit, targetTemperature, mode
// like "[true,'auto','C',21,'heat']"
// to turn off AC,first parameters = false : "[false,'auto','C',21,'heat']"
// one_off : boolean value to enable/disable the Climate React
// unit : Passing F for Farenheit or C for Celcius
// Some examples:
// Range 19-24 Celcius, start to heat to 22 at auto fan if the temp is lower than 19 and stop the AC when higher than 24
// configureClimateReact(19, 24, ‘temperature’, ‘[true, ‘auto’, ‘C’, 22, ‘heat’]’, ‘[false, ‘auto’, ‘C’, 22, ‘heat’]’, true, ‘C’);
// Range 67-68 Farenheit, start to heat to 68 at auto fan if the temp is lower than 67 and stop the AC when higher than 68
// configureClimateReact(67, 68, ‘temperature’, ‘[true, ‘auto’, ‘F’, 68, ‘heat’]’, ‘[false, ‘auto’, ‘F’, 68, ‘heat’]’, true, ‘F’);
displayTraceLog( "configureClimateReact() called")
if (ThresUnit.toUpperCase() == "F")
lowThres = fToc(lowThres).round(1)
highThres = fToc(highThres).round(1)
def json = new groovy.json.JsonBuilder()
def lowStateMap = evaluate(lowState)
def highStateMap = evaluate(highState)
def lowStateJson
def highStateJson
if (lowStateMap) {
lowStateJson = json {
on lowStateMap[0]
fanLevel lowStateMap[1]
temperatureUnit lowStateMap[2]
targetTemperature lowStateMap[3]
mode lowStateMap[4]
else { lowStateJson = null }
if (highStateMap) {
highStateJson = json {
on highStateMap[0]
fanLevel highStateMap[1]
temperatureUnit highStateMap[2]
targetTemperature highStateMap[3]
mode highStateMap[4]
else { highStateJson = null }
def root = json {
deviceUid device.deviceNetworkId
highTemperatureWebhook null
highTemperatureThreshold highThres
lowTemperatureWebhook null
type stype
lowTemperatureState lowStateJson
enabled on_off
highTemperatureState highStateJson
lowTemperatureThreshold lowThres
displayDebugLog("CLIMATE REACT STRING : " + JsonOutput.prettyPrint(json.toString()))
def result = parent.configureClimateReact(this, device.deviceNetworkId, json.toString())
if (result) {
displayInfoLog( "Climate React settings changed for " + device.deviceNetworkId)
sendEvent(name: 'Climate', value: on_off, displayed: false)
refresh()
else {
def switchFanLevel() {
displayTraceLog( "switchFanLevel() called")
def currentFanMode = device.currentState("fanLevel")?.value
displayDebugLog("switching fan level from current mode: $currentFanMode")
def returnCommand
switch (currentFanMode) {
case "low":
returnCommand = dfanLevel("medium")
break
case "medium":
returnCommand = dfanLevel("high")
break
case "high":
returnCommand = dfanLevel("auto")
break
case "auto":
returnCommand = dfanLevel("quiet")
break
case "quiet":
returnCommand = dfanLevel("medium_high")
break
case "medium_high":
returnCommand = dfanLevel("medium_low")
break
case "medium_low":
returnCommand = dfanLevel("strong")
break
case "strong":
returnCommand = dfanLevel("low")
break
returnCommand
def GetNextMode(mode, modes) {
displayTraceLog( "GetNextMode called with " + mode)
def listMode = ['heat','cool','fan','dry','auto']
def newMode = returnNext(listMode, modes,mode)
displayDebugLog("Next Mode = " + newMode)
return newMode
def NextMode(sMode) {
displayTraceLog( "NextMode called()")
if (sMode != null) {
switch (sMode) {
case "heat":
modeHeat()
break
case "cool":
modeCool()
break
case "fan":
modeFan()
break
case "dry":
modeDry()
break
case "auto":
modeAuto()
break
else
return null
def GetNextSwingMode(swingMode, swingModes){
displayTraceLog( "GetNextSwingMode() called with " + swingMode)
if (swingModes == null || swingModes == "null") {
return null
def listSwingMode = ['stopped','fixedTop','fixedMiddleTop','fixedMiddle','fixedMiddleBottom','fixedBottom','rangeTop','rangeMiddle','rangeBottom','rangeFull','horizontal','both']
def newSwingMode = returnNext(listSwingMode, swingModes,swingMode)
displayDebugLog("Next Swing Mode = " + newSwingMode)
return newSwingMode
def switchSwing() {
displayTraceLog( "switchSwing() called")
def currentMode = device.currentState("swing")?.value
displayDebugLog("switching Swing mode from current mode: $currentMode")
def returnCommand
case "stopped":
returnCommand = modeSwing("fixedTop")
break
case "fixedTop":
returnCommand = modeSwing("fixedMiddleTop")
break
case "fixedMiddleTop":
returnCommand = modeSwing("fixedMiddle")
break
case "fixedMiddle":
returnCommand = modeSwing("fixedMiddleBottom")
break
case "fixedMiddleBottom":
returnCommand = modeSwing("fixedBottom")
break
case "fixedBottom":
returnCommand = modeSwing("rangeTop")
break
case "rangeTop":
returnCommand = modeSwing("rangeMiddle")
break
case "rangeMiddle":
returnCommand = modeSwing("rangeBottom")
break
case "rangeBottom":
returnCommand = modeSwing("rangeFull")
break
case "rangeFull":
returnCommand = modeSwing("horizontal")
break
case "horizontal":
returnCommand = modeSwing("both")
break
case "both":
returnCommand = modeSwing("stopped")
break
returnCommand
def modeSwing(String newSwing) {
displayTraceLog( "modeSwing() called with " + newSwing)
def SwingBefore = device.currentState("swing").value
def Swing = SwingBefore
def Swings = capabilities.remoteCapabilities.swing
displayDebugLog("Swing capabilities : " + capabilities.remoteCapabilities.swing)
Swing = GetNextSwingMode(newSwing,capabilities.remoteCapabilities.swing)
//displayDebugLog("Swing : " + Swing)
def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, Swing, device.currentState("temperatureUnit").value)
if (result) {
displayInfoLog( "Swing mode changed to " + Swing + " for " + device.deviceNetworkId)
sendEvent(name: 'swing', value: Swing, displayed: false,isStateChange: true)
generateSwingModeEvent(Swing)
refresh()
else {
else {
//TODO
def generateSwingModeEvent(mode) {
sendEvent(name: "swing", value: mode, descriptionText: "$device.displayName swing mode is now ${mode}", displayed: true, isStateChange: true)
private getThermostatDescriptionText(name, value, linkText) {
if(name == "temperature") {
return "$name was $value " + device.currentState("temperatureUnit").value
else if(name == "humidity") {
return "$name was $value %"
else if(name == "targetTemperature") {
return "latest temperature setpoint was $value " + device.currentState("temperatureUnit").value
else if(name == "fanLevel") {
return "latest fan level was $value"
else if(name == "on") {
return "latest switch was $value"
else if (name == "mode") {
return "thermostat mode was ${value}"
else if (name == "currentmode") {
else if (name == "powerSource") {
return "power source mode was ${value}"
else if (name == "Climate") {
return "Climate React was ${value}"
else if (name == "thermostatMode") {
else if (name == "temperatureUnit") {
return "thermostat unit was ${value}"
else if (name == "voltage") {
return "Battery voltage was ${value}"
else if (name == "battery") {
return "Battery was ${value}"
else if (name == "voltage" || name== "battery") {
else if (name == "swing") {
return "Swing mode was ${value}"
else if (name == "Error") {
def str = (value == "Failed") ? "failed" : "success"
return "Last setACState was ${str}"
else {
return "${name} = ${value}"
// parse events into attributes
displayDebugLog("Parsing '${description}'")
def name = null
def value = null
def statusTextmsg = ""
def msg = parseLanMessage(description)
def headersAsString = msg.header // => headers as a string
def headerMap = msg.headers // => headers as a Map
def body = msg.body // => request body as a string
def status = msg.status // => http status code of the response
def json = msg.json // => any JSON included in response body, as a data structure of lists and maps
def xml = msg.xml // => any XML included in response body, as a document tree structure
def data = msg.data // => either JSON or XML in response body (whichever is specified by content-type header in response)
if (description?.startsWith("on/off:")) {
displayDebugLog("Switch command")
name = "switch"
value = description?.endsWith(" 1") ? "on" : "off"
else if (description?.startsWith("temperature")) {
displayDebugLog("Temperature")
name = "temperature"
value = device.currentValue("temperature")
else if (description?.startsWith("humidity")) {
displayDebugLog("Humidity")
name = "humidity"
value = device.currentValue("humidity")
else if (description?.startsWith("targetTemperature")) {
displayDebugLog("targetTemperature")
name = "targetTemperature"
value = device.currentValue("targetTemperature")
else if (description?.startsWith("fanLevel")) {
displayDebugLog("fanLevel")
name = "fanLevel"
value = device.currentValue("fanLevel")
else if (description?.startsWith("currentmode")) {
displayDebugLog("mode")
name = "currentmode"
value = device.currentValue("currentmode")
else if (description?.startsWith("on")) {
displayDebugLog("on")
name = "on"
value = device.currentValue("on")
else if (description?.startsWith("switch")) {
displayDebugLog("switch")
name = "switch"
else if (description?.startsWith("temperatureUnit")) {
displayDebugLog("temperatureUnit")
name = "temperatureUnit"
value = device.currentValue("temperatureUnit")
else if (description?.startsWith("Error")) {
displayDebugLog("Error")
name = "Error"
value = device.currentValue("Error")
else if (description?.startsWith("voltage")) {
displayDebugLog("voltage")
name = "voltage"
value = device.currentValue("voltage")
else if (description?.startsWith("battery")) {
displayDebugLog("battery")
name = "battery"
value = device.currentValue("battery")
else if (description?.startsWith("swing")) {
displayDebugLog("swing")
name = "swing"
value = device.currentValue("swing")
def result = createEvent(name: name, value: value)
displayDebugLog("Parse returned ${result?.descriptionText}")
return result
def ping(){
displayTraceLog( "calling parent ping()")
return parent.ping()
Something that I have noticed is that there is potential to do more logical comparison to fire changes in a more controlled way. At the moment if anything changes it does a change on all attributes. I'll put it on the list
