I'm creating a rule based on multiple switches as a trigger and had a question.
In my test code, I was using IF (Switch1 is on OR Switch2 is on) THEN do stuff
. This worked no problems
I'm now going back and cleaning up the rule a bit and am now doing IF (Switch1, Switch2 any is on) THEN do stuff
I haven't tested it yet as I'm still completing the rest of the rule, but just wanted to know before I go through and complete it all that these should operate the same, right? Any reason to use one over another? I get if you're using different types of triggers (e.g. 1 switch OR 1 contact sensor), but since they're both the same type, this was put to make our lives easier, right?
Good to know. I'll keep that in mind for future events if I want to use notifications. Thankfully for this rule, I don't need to notify anything. I'm looking to control some somfy blinds by tapping into a secondary remote via relays, so I won't need to notify of anything. If I do use it for contact sensors though, I'll look to use OR instead of any
(Posted in response to a question--now edited, but I'll leave this here in case it's still helpful--about whether a single "any" trigger would show the specific triggering devices for %device%
or just the specific device:)
This:
Gives this outcome when Switch 1 is turned on (similar for Switch 2 or off, etc.):
(bottom log entry from device, top from RM)
One area where I know multiple "OR" triggers vs. one single "any" trigger matters is with triggers like: "Switch 1, Switch 2, Switch 3 any on" compared to "Switch 1 on OR Switch 2 on OR Switch 3 on." Here, any switch changing (to any value) will match the first ("any") trigger as long as one or more of those switches is still on. The latter trigger--which I think a lot of people intend to do when they write something like the first--will trigger only on a specific switch turning on. But with conditionals inside a rule (the specific scope of this question, though both are good to know), I'm not aware of any differences.
I am probably confused, but I remember when Rule 4.0 came out I tried doing a battery notification rule with something like "Device1, Device2, Device3 any < 50". All of my battery devices were listed in the notification when one fell below the threshold. "Device1 <50 OR Device2 < 50 OR Device3 < 50" just gave me the single device.(But who really wants to do all that?)
It was a while ago!
Yeah, I'd definitely much rather use a purpose-built app for that!* Maybe earlier builds of RM 4.0 worked differently. With the single "any" trigger, what would definitely happen (at least now) is that you'd get a notification with one specific device name any time any device reported a battery level and one (or more) happened to be below that level, even if it wasn't the specific device that triggered the rule and even if that particular device had a level above the threshold.
*actually, I gave up on battery monitoring at all in favor of device activity ... but I feel like at some point I'll try to add it back for devices I care about once I figure out what good thresholds might be, should any actually be reliably "good"
Thanks for correcting me! First post deleted.
You could still be right--I'm not sure if earlier versions were different. But I've modified my post to reflect that it's now just an example of a question that is no longer here. Hopefully it's still helpful to anyone curious!
Thank you both for the insight. Here's to hoping this post is still relevant with future iterations of RM
