RM 5.1 (2.2.9.146)
I have rebooted, but have not tried a Soft Reset.
Creating a new rule:
Add boolean Hub variable trigger:
Look what happens to trigger when I set dimmer to Hub variable number:
RM 5.1 (2.2.9.146)
Perhaps the Red "Not Installed" message is a factor?
Did you click "install Rule" ?
Yes, after installing it still has the very strange trigger. Standard-OnLevel is a number, not boolean. The trigger started off as FoyerMotion but changed when I added the action.
Can you recreate it or is it me?
Yep, I am able to recreate exactly the bug you reported using a virtual dimmer. The variable trigger changes when the Set Dimmer is added. Tagging @bravenel.
Tested on C-5, 2.2.9.146, RM 5.1
I'm sorry, but what is the bug? How do I recreate it?
I found it. Setting a dimmer to a variable level changes the trigger, right?
Can get that fixed. Overloaded setting name, two uses stepping on each other.
Yep.
Yipeeeee, its not me
Yes, it’s you, but there is also a bug. Wow, that must have caused a bit of head scratching. What an odd bug.
