Any idea what this is. What is app 2
This is what i am seeing in the log. Any idea what it is or how to clean it up.
sys:12021-05-05 10:40:25.931 am Received cloud request for App 2 that does not exist, path: /menu/presence/42 from XXX.XXX.XXX.XXX
sys:12021-05-05 10:40:25.762 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 10:40:25.756 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 10:40:25.749 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 10:40:25.741 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 10:40:24.611 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 10:40:24.500 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:41.252 am Received cloud request for App 2 that does not exist, path: /menu/presence/42 from XXX.XXX.XXX.XXX
sys:12021-05-05 08:05:41.017 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:41.012 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:41.011 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:41.003 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:39.950 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:39.829 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:39.801 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:38.744 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:38.609 am Received local request for App 2 that does not exist, path: /menu from unknown
sys:12021-05-05 08:05:38.595 am Received local request for App 2 that does not exist, path: /menu from unknown
I think that may be coming from an instance of the Hubitat Mobile App that is no longer configured correctly. I would uninstall the Hubitat Mobile App from whatever device is sending these packets, and then reinstall it and select the correct Hubitat hub. Let us know if that resolves the issue.
Done,
A little strange in that when I opened up the newly installed instance and logged in it gave me two devices to chose from. I checked the hubitat device screen and found two phone devices. I removed the one that isn't needed or associated with anything and linked to my existing one. If that still creates the problem i am going to remove this one and then try again. Will let you know the results.
I've seen the same behavior. Log out of app, log in; select hub, shows existing device or create new select existing, it creates a new device w same name of exisiting device but with a different DNI w no in use by..
