Another hub lockup
The assumption that "outside code" is causing the problem is a bit opaque.
There should be some information to developers as to what are the problems that may arise.
  • It is well known if you go compute bound / infinite loop you can cause problems. But what happens after that has been eliminated?
I do think there there are system level memory leaks, and db problems that build up over time. Since "outside code" does not allocate / deallocate memory, nor control the db in any api fashion, it stands to reason they cannot be held responsible for these issues...ie they should not be able to cause system level leaks and lockups.
I expect most if not all the systems having this problem are not "infinite loop" problems, so there should be more debugging going on at the system level vs. "just keep removing things". It would be good to understand what the "offender" is doing wrong / what resource is being depleted. Either that or we need some counter so we know when to do a reboot/restart....
Is there really no way to get a memory dump of what is running state out of the hub? This instability is becoming reminiscent of ST instability that could never be explained and causes many to want to abandon it.
