Can anyone tell me if its possible using rule machine to have it announce the temperature of my aeotec 6 mulisensor when the temperature changes but it changes by a degree not .degree?
I have it setup now and it works fine but i only want it to announce it when it changes from say 14 deg to 15 degrees not 16.44 -> 16.45
Could make a global variable and set it to the temp. Then compare it to the temp when the difference is GE 1 or LE 1 and at that point reset the variable to that temp.
Hall_Temp is a global variable I defined and initialized to zero so the first time you save the rule you can reload it and hit Run Actions and it will set the initial value and it will message you and then it would do so after that. You could of course then add other rules for time of day restrictions etc but that's the basics.
I think there is a small typo in tivo's rule. I think the first condition in the 'if' statement should be Hall_temp - 1.0 and not Hall_temp +1.0. In the example above you want to get notified when the actual temp is less than 75.9 - 1 = 74.9 or above 75.9 + 1 = 76.9,
Edit: To get round numbers you'd have to initialize the Hall_Temp to a round number first (like 23.0), then the rule would only enunciate round numbers. However, it would still be possible to get off by a decimal. For instance, if your temp value is 23.0 and the actual temp goes from 23,1 to 22.9 then your new temp value would be with a .9. If your reporting device does not jump more than .1 then you should be OK and the round numbers will stay.
In RM there is an area to 'create global variable' in there you can set the initial value.
New global variable: Hall_Temp, type: decimal, initial value: pick something close to the current temp and use xx.0.
Maybe, you can select type 'numeric' instead (which I believe should be integer type) and it will automatically just use whole numbers. I haven't used global vars so I don't know for sure, you'd have to see if that would work.
I think I have a solution that could work using a rule to round the variable. Posted it here as a response to a different thread.
This screenshot is a simpler version if you just want to set the variable as the round off number. Could use local or global variable in the variable math.
