When repairing a device - say after a battery change, the presented screen confuses.
I would ask that when a device is found the wording be changed to :
Found x previously joined device and reconnected to the hub.
then, I would change the Dismiss button to say 'Stop searching and exit'. or 'Stop further search'.
In this way, you inform the user the task was completed, and they can exit without waiting for the timer.
Currently, I interpret this as 'found a device' and then it implies to click it since its a blue URL to the device. Going back to the device actually isn't a good thing, since the logical is to push configure when you get to it, which is a bad thing in many cases. And Dismiss implies 'nevermind'.
