Amazon Echo Skill not showing up under either Integrations or Apps
Hi all, longtime user but first-time poster. C-8 hub, running 2.5.1.183.
While troubleshooting a recent connection problem with Amazon Alexa I decided to reset the connection and removed the Amazon Echo Skill.
When I went to re-add Amazon Echo Skill, I noticed that the app was missing from the list of Built-In Integrations. Thinking that it might have been moved to Apps, I looked there but it was not on the list of built-in Apps.
Where did Amazon Echo Skill go?
Good question! I just went looking for it on my C8 development hub and do not see it listed as a an available app to install under Apps, Automations, or Integrations.
However, there was a recent change regarding Voice Assistants in a recent release. If you go to any one of your devices that are eligible to be shared with a Voice Assistant, you will see a new Tab at the top called "Assistants". Perhaps following the linked instructions, highlighted below, is now the intended method to initially get things going?
which takes you to
Amazon Echo Skill | Hubitat Documentation
Which explains that the process is to be initiated from within the Amazon Alexa mobile app side of things. This is actually the workflow that I have always preferred as simply enabling the Hubitat Skill on the Alexa side of things, and then choosing the registered Hubitat hub from your Hubitat cloud account, will automagically install the Amazon Echo Skill app on your Hubitat hub.
Hope this helps!
Confirmed that enabling the Hubitat Skill at the Alexa {app,website} causes the HE hub to automagically install the Amazon Echo Skill after providing Hubitat credentials via the Alexa {app,website}.
Valid for C-8 Pro, ver. 2.5.2.129
that realkly doesnt help i already have it linked and installed and its not showing up.. how do i make changes.. this looks like a bug to me...
@gopher.ny
What platform version is your hub on?
Working for me on the latest Production 2.5.2.129 release...
Same here.
I’m not sure why there would be reason to suspect a platform-wide bug related to this.
I seem to recall this was an issue with an older beta platform release. But that was a while back.
