[ALPHA] Mobile Controller - Bring Your Android Devices Into Your Smart Home
You can also use HTTP commands instead of use auto remote, but both should work.
Did I add that I have included (in my local version) the ability to play TTS... Helped me find my phone tonight (this morning).
HPM says I have the latest version of MC but I don't see how to send TTS. Any tips?
I haven't released that feature yet, getting closer... hopefully this weekend I might get some more time to look at it.
So, it seems my android box is not allowing the tasker port (or any port) to be open. Any ideas on how to fix this?
Hmmm... I'm not sure. What type of android device are you using?
Its an android tv box. Btv13. Installation of tasker runs fine, and im able to import the project, but after that, app on hubitat logs an error of no response.
You might have to leave that one with me.... I started to look at this again yesterday, trying to set it up on my new phone. This was one of the things I saw but couldn't quite pin down the exact reason. It did seem to make a difference if I reduced the number of calls being made in quick succession to the phone by adjusting the driver / app code, but I need to spend some more time on it to properly work out what is happening. I am working with a much more progressed version of the HE code and Tasker setup, so it sounds like it may not be so much something in what I have developed but some kind of limitation I need to manage.
I seem its not related to the number of calls, as none of them will reach the andoid box... and no commands will work. I'll run some additional networks tests here to see if i can find anything. Also, I'm happy to beta test if you need any help!!
I have painted myself into a corner with partially completed features, along with little time to spend on this... :slight_smile: am trying to get to any kind of workable release to allow testing... When I have time... So appreciate the offer....
Hi, Simon. Just checking in to let you know I'm still using this in the alpha-beta version.
Thanks for the poke / reminder @CAL.hub , you'd be surprised how much it helps someone like me....
I have been using (and developing) this to varying degrees and would like to still see it make it beyond Alpha. Life has a way of getting in the way, including making a compelling case why it matters more than things like this. Life might be starting to lose that argument, so I might have a chance to move this forward, but we will see...
