[Alpha] Community-maintained Google Home integration
Thanks for this app. Really great.
I'm using the sonoff temp and humidity sensor with the driver described here:
I've created the Google Home Community App
I've created created a device "Temp Sensor"
The device config:
Device type name* Temp Sensor
Device type * Temperature Measurement
Google Home device type * Thermostat
Device Traits: Temperature Setting
  • This has the "Query only" enabled
This appears in my google home app with the correct temperature displayed.
There is also a "on/off" button (not sure why that's there).
For some reason I can't use this device as an automation starter in either the phone app or the google home script editor. Does anyone have any idea if there's a something I can change to get this device to be used as a starter?
