All the rules I created with visual rule builder stopped working on C8 Pro
All the rules I created with visual rule builder stopped working on C8 Pro.
Platform Version
2.4.3.177
I deleted all rules and created a new one to activate in 5 minutes. The rule never executed.
Also rebooted.
The only thing that I did before this happened was change to ZWaveJs and remove 5 ghost nodes then went back.
Please Help
Shut down the hub remove power and then restore after 10 seconds.
If you had ghosts then this will remove their final slimy gooey bits
Tried that multiple times. Tried everything including all AI solutions. Been trying all day to fix this but I need to have thermostats heat in morning and I need to get going. I dread this but I'm going to do a soft reset.
soft reset and a restore of a DB is not a "bad" thing its a really easy way of cleaning up your DB with no losses. So yeah next i would give that ago.
It worked. Probably the Leviton switches. The don't play nice with my hubitat. Always create ghosts and usually freeze some funtion of the hub when trying to pair.
Which specific Leviton switches do you have? My Leviton Dimmers (DZ6HD) seem to play nice; but the Leviton fan controller (ZW4SF) (which I have posted about separately) can randomly hang every ~3 months or so.. and it takes out local physical switch control as well. Only an airgap (circuit breaker) reset toggle brings it back.
The VRS15-1L and the VRIØ6-1L are the problem. I can't pair them to the C8. When I try, things go bad. They paired to the C7. The new ZW15 S pairs to the C8 but I need to be 1 foot away.
Have not tried the DZ6HD Dimmer.
