All my devices are not compatible. Any work around?
Welcome to the Hubitat forums!
Which model? The Zwave ones are technically possible to join to the hub. But because of mixed experiences Hubitat removed the Zwave model from the compatibility list. There is a driver for these locks.
These do work, but you have to be very careful as to your mix of devices. Aqara are picky about the routers they work with, and about working with particular devices. There is a thread about this that may be helpful. Xiaomi & Aqara Devices - Pairing & Keeping them connected
There are various community based drivers for most of these devices, I would use the search with the model numbers to find which have drivers.
I am not as familiar with these, but there are built-in drivers for Generic Zigbee Shade that might possibly work. (Assuming these are Zigbee, you didn't say). There are also community drivers that could possibly work, you might try searching for these too if the built-in driver doesn't work.
The documentation is helpful as is their Youtube channel I linked below. Here is the general documentation link. https://docs.hubitat.com/index.php?title=Documentation
You probably specifically should look at the section for how to install community driver code. https://docs.hubitat.com/index.php?title=How_to_Install_Custom_Drivers
If you need to install community based drivers, this Hubitat video from their Youtube channel outlines this process. There are tons of other terrific videos here too, you should watch a few of these to get familiar with things.
