Probably a simple answer, but how do you TOP Align the data/rows in these tiles that I have in my Dashboard? I want the rows in the various tiles to align. Several of the tiles are now CENTER aligning the rows/data in the tile. Where do I insert the CSS to correct this? Can you provide the example for me? Thanks,
I tried to add: } #tile-109[style="background-position"] {*
** background-position: top;** }
This did not work. It appears I am trying to Top align the table in the tile. Perhaps the "tbody". Not sure. Help?
I bookmarked this to look at this later today, if you can wait... I just need to look at the DIV element that the attribute contents sits in and whether we can add an alignment style element through CSS. One issue may be whether the DIV sits within another and is condensed, meaning it may be hard to get the contents at the top of the tile.
If you are familiar with the Developer Tools in your browser you could likely work out the element references needed in CSS by traversing the contents of the dashboard. It's not a bad exercise to go through to familiarise yourself with the structure.
I can wait. No hurry. Thanks. I've tried inspecting the page and all I see is the tile number (107 in this case) and a table. I'm not a developer. Seems like others would have top aligned data tables/rows in dashboard tiles on Hubitat. Any help is appreciated.
Nice work drilling down to the tile. Hover over the tile-contents div, two rows below tile div you have highlighted on the right, it should hopefully highlight the section of the tile on the left in the actual dashboard, that will give you an idea of whether the div that contains the TB table is a "snug" fit for the table, or if it extends up to the top of the tile.
Yeah, not as simple as it could be. I have setup an editor for things like this, but don't include this at the moment. Too many other projects to keep my occupied.
It's not the table contents that we need to align, it's outside of that... Though I can't quite get it to work as I expect.... I'll keep trying...
There is some standard CSS code available in the Rooms module that makes sure that TB content expands to completely fill the tile container. Not in a position to give specifics at the moment but itโs in there.
There are 5 unique modules in Tile Builder, one of which is called Rooms. If you look at the very first post in this thread you will see each of the 5 discussed with examples.
This was the code I was referring to that might be useful.
/* This CSS generated by Tile Builder Rooms version: Tile Builder Rooms v1.1.0 (9/21/23 @ 08:24 PM) /
/ Make the tile background transparent and allow all the tiles to overflow to adjacent tiles./
[class='tile']{background-color:rgba(128,128,128,0) !important; overflow:visible !important}
/* Hide all of the Tile Titles. /
[class='tile-title']{visibility:hidden}
/* Make sure the contents expand to fill the entire tile and eliminate the gaps between the tiles. If there are still gaps make sure setting Gridgap on Layout tab is set to a 0 between quotation marks! /
[class='tile-contents']{width:calc(100% - var(--myRoomGap) ) !important; height:calc(100% - var(--myRoomGap) ) !important}
/* Make sure the image tiles are configured correctly. The image fills the tile and the tiles are place in the far background. */
.tile.image .inset-auto img {object-fit:fill}
.tile.image {background-color: rgba(128,128,128,0) !important; z-index:-3 !important}
/* Hide any classes using the 3d_rotation symbol/class and then append some visible text which has the effect of replacing it. 3d_rotation is the first in the picklist so it has been picked for convenience./
[class='3d_rotation']{visibility:hidden}
[class*='3d_rotation']::after{color:green; visibility:visible !important;content:'\00A0\00A0\00A0\00A0'; transform:translateX(-100%) !important; position: absolute; outline: 2px dotted blue}
