Alexa without skill
I read somewhere about an app on hubitat, some hue bridge emulator, which allows to control devices with alexa but without adding skill and does not require cloud access.
Alexa app is really terrible how it looks and work. I would like to use that app. How to install it on hubitat?
Besides I connect everything thru free vpn on router and often get message “cant connect to cloud” when trying to log in to my hubitat com Not sure would be able to use skill as it requires to log in to my hubitat
We don't usually announce upcoming features, but since this came up... there will be an easier way to add device to Alexa/Google/HomeKit in the next public 2.5.1 release. The exact appearance may change, but you get the idea...
Clarify your network topology and it is likely the community will assist you in getting the built-in Amazon Echo Skill to work.
This app was not very functional vis-a-vis device types and was deprecated in favor of the Amazon Echo Skill many years ago. It is no longer available for installation. I will reiterate that it should be possible to get the Amazon Echo Skill to work even if your hub is behind a VPN, as long as that VPN is properly configured.
Thanks I will try today’s release and “normal” skill.
Perhaps later local ai with bluetooth speakerphone when I get more familiar with hub
Not sure what you meant about topology, i have openwrt router with always-on vpn on it and few switches
Can you clarify is this an alternate UI for controlling the settings on the existing integrations or is this a new way to integrate? I am assuming the former.
Correct.
If the corresponding assistant app is not installed, the buttons are disabled (grayed out). There are links to install the apps, at the bottom. Once the app is installed, you can share a device with a voice assistant from the device details page without opening the app. Opening the app is still an option:
