Alexa - -Unsolicited TTS
From my windows PC I just opened a command prompt and used the IP of my pi.
Telnet 192.168.1.121
It prompted for username and password. I then pasted in the command and my echo spoke as expected. I see the results on the command prompt.
I am really in over my head. I know just enough to break things usually. Give me blood gases and mechanical ventilators any day lol.
I am going to try a different route with node red and http calls. I can usually make a good ol get work
Can you please share the procedure and scripts to get the Raspberry Pi working to be able to get TTS working on an Echo?
Once we have that code, I am sure there are a few of us that would love to take a try at creating an integration with Hubitat (e.g. Telnet, NodeJS server, etc...) The most ideal integration would be directly from Hubitat to Amazon, if possible.
Hi @ogiewon Absolutely,
Everything I have done is in the repo in the first post.
GitHub - walthowd/ha-alexa-tts: Alexa Unsolicted TTS for Home Assistant - I copied the one file to my pi, hardcoded my email and password. Commented out the line about the YAML file then executed.
The login never worked for me as with many others noted in the issues on the github. So I did the login to firefox and copy the cookie route.
This command gives you a list of devices
./alexa_remote_control.sh -a
This command makes her speak
`./alexa_remote_control.sh -d "My Dot Name" -e speak:This_is_a_test!`
#!/bin/sh
# Amazon Alexa Remote Control
#  alex(at)loetzimmer.de
# 2017-10-10: v0.1 initial release
# 2017-10-11: v0.2 TuneIn Station Search
# 2017-10-11: v0.2a commands on special device "ALL" are executed on all ECHO+WHA
# 2017-10-16: v0.3 added playback of library tracks
# 2017-10-24: v0.4 added playback information
# 2017-11-21: v0.5 added Prime station and playlist
# 2017-11-22: v0.6 added Prime historical queue and replaced getopts
# 2017-11-25: v0.6a cURL is now configurable
# 2017-11-25: v0.7 added multiroom create/delete, playback of library playlist
# 2017-11-30: v0.7a added US config, fixed device names containing spaces
# 2017-12-07: v0.7b added Bluetooth connect/disconnect
# 2017-12-18: v0.7c fixed US version
# 2017-12-19: v0.7d fixed AWK csrf extraction on some systems
# 2017-12-20: v0.7e moved get_devlist after check_status
# 2018-01-08: v0.7f added echo-show to ALL group, TuneIn station can now be up to 6 digits
# 2018-01-08: v0.8 added bluetooth list function
# 2018-01-10: v0.8a abort when login was unsuccessful
# 2018-01-25: v0.8b added echo-spot to ALL group
# 2018-01-28: v0.8c added configurable browser string
# 2018-02-17: v0.8d no need to write the cookie file on every "check_status"
# 2018-02-27: v0.8e added "lastalexa" option for HA-Bridge to send its command to a specific device
#		(Markus Wennesheimer: https://wennez.wordpress.com/light-on-with-alexa-for-each-room/)
# 2018-02-27: v0.9 unsuccessful logins will now give a short info how to debug the login
# 2018-03-09: v0.9a workaround for login problem, force curl to use http1.1
# 2018-05-17: v0.9b update browser string and accept language
# 2018-05-23: v0.9c update accept language (again)
# 2018-06-12: v0.10 introducing TTS and more
#       (thanks to Michael Geramb and his openHAB2 Amazon Echo Control binding)
#		https://github.com/openhab/openhab2-addons/tree/master/addons/binding/org.openhab.binding.amazonechocontrol
#		(thanks to Ralf Otto for implementing this feature in this script)
# 2018-06-13: v0.10a added album play of imported library
# 2018-06-18: v0.10b added Alex routine execution
# (no BASHisms were used, should run with any shell)
# - requires cURL for web communication
# - (GNU) sed and awk for extraction
# - jq as command line JSON parser (optional for the fancy bits)
# EMAIL and PASSWORD are set on the keys 'alexa_email' and 'alexa_password'
# in your secrets.yaml file.
SECRETS_YAML='/home/homeassistant/.homeassistant/secrets.yaml'
#SECRETS_YAML='/config/secrets.yaml'
#LANGUAGE="de-DE"
#LANGUAGE="en-GB"
LANGUAGE="en-US"
#AMAZON='amazon.de'
#AMAZON='amazon.co.uk'
AMAZON='amazon.com'
#ALEXA='layla.amazon.de'
#ALEXA='layla.amazon.co.uk'
ALEXA='pitangui.amazon.com'
# binaries
CURL='/usr/bin/curl'
AWK='/usr/bin/awk'
SED='/bin/sed'
# cURL options
#  -k : if your cURL cannot verify CA certificates, you'll have to trust any
#  --compressed : if your cURL was compiled with libz you may use compression
#  --http1.1 : cURL defaults to HTTP/2 on HTTPS connections if available
OPTS='--compressed --http1.1'
#OPTS='-k --compressed --http1.1'
# browser identity
BROWSER='Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0'
# nothing to configure below here
TMP="/tmp"
COOKIE="${TMP}/.alexa.cookie"
DEVLIST="${TMP}/.alexa.devicelist.json"
GUIVERSION=0
LIST=""
LOGOFF=""
COMMAND=""
TTS=""
UTTERANCE=""
SEQUENCECMD=""
STATIONID=""
QUEUE=""
SONG=""
ALBUM=""
ARTIST=""
TYPE=""
ASIN=""
SEEDID=""
HIST=""
LEMUR=""
CHILD=""
PLIST=""
BLUETOOTH=""
LASTALEXA=""
usage()
	echo "$0 [-d <device>|ALL] -e <pause|play|next|prev|fwd|rwd|shuffle|vol:<0-100>> |"
	echo "          -b [list|<\"AA:BB:CC:DD:EE:FF\">] | -q | -r <\"station name\"|stationid> |"
	echo "          -s <trackID|'Artist' 'Album'> | -t <ASIN> | -u <seedID> | -v <queueID> | -w <playlistId> |"
	echo "          -i | -p | -P | -S | -a | -m <multiroom_device> [device_1 .. device_X] | -lastalexa | -l | -h"
	echo
	echo "   -e : run command, additional SEQUENCECMDs:"
	echo "        weather,traffic,flashbriefing,goodmorning,singasong,tellstory,speak:'<text>',automation:'<routine name>'"
	echo "   -b : connect/disconnect/list bluetooth device"
	echo "   -q : query queue"
	echo "   -r : play tunein radio"
	echo "   -s : play library track/library album"
	echo "   -t : play Prime playlist"
	echo "   -u : play Prime station"
	echo "   -v : play Prime historical queue"
	echo "   -w : play library playlist"
	echo "   -i : list imported library tracks"
	echo "   -p : list purchased library tracks"
	echo "   -P : list Prime playlists"
	echo "   -S : list Prime stations"
	echo "   -a : list available devices"
	echo "   -m : delete multiroom and/or create new multiroom containing devices"
	echo "   -lastalexa : print device that received the last voice command"
	echo "   -l : logoff"
	echo "   -h : help"
# Read yaml file and generate variables.
# Github driven development. https://gist.github.com/pkuczynski/8665367
parse_yaml()
local prefix=$2
local s='[[:space:]]*' w='[a-zA-Z0-9_]*' fs=$(echo @|tr @ '\034')
${SED} -ne "s|^\($s\)\($w\)$s:$s\"\(.*\)\"$s\$|\1$fs\2$fs\3|p" \
    -e "s|^\($s\)\($w\)$s:$s\(.*\)$s\$|\1$fs\2$fs\3|p"  $1 |
${AWK} -F$fs '{
  indent = length($1)/2;
  vname[indent] = $2;
  for (i in vname) {if (i > indent) {delete vname[i]}}
  if (length($3) > 0) {
     vn=""; for (i=0; i<indent; i++) {vn=(vn)(vname[i])("_")}
     printf("%s%s%s=\"%s\"\n", "'$prefix'",vn, $2, $3);
eval $(parse_yaml ${SECRETS_YAML} "secrets_")
EMAIL=${secrets_alexa_email}
PASSWORD=${secrets_alexa_password}
while [ "$#" -gt 0 ] ; do
	case "$1" in
		-d)
			if [ "${2#-}" != "${2}" -o -z "$2" ] ; then
				echo "ERROR: missing argument for ${1}"
				usage
				exit 1
			fi
			DEVICE=$2
			shift
		-e)
				usage
				exit 1
			fi
			COMMAND=$2
			shift
		-b)
			if [ "${2#-}" = "${2}" -a -n "$2" ] ; then
				BLUETOOTH=$2
				shift
			else
				BLUETOOTH="null"
			fi
		-m)
				usage
				exit 1
			fi
			LEMUR=$2
			shift
			while [ "${2#-}" = "${2}" -a -n "$2" ] ; do
				CHILD="${CHILD} ${2}"
				shift
			done
		-r)
				usage
				exit 1
			fi
			STATIONID=$2
			shift
			# stationIDs are "s1234" or "s12345"
			if [ -n "${STATIONID##s[0-9][0-9][0-9][0-9]}" -a -n "${STATIONID##s[0-9][0-9][0-9][0-9][0-9]}" -a -n "${STATIONID##s[0-9][0-9][0-9][0-9][0-9][0-9]}" ] ; then
				# search for station name
				STATIONID=$(${CURL} ${OPTS} -s --data-urlencode "query=${STATIONID}" -G "https://api.tunein.com/profiles?fullTextSearch=true" | jq -r '.Items[] | select(.ContainerType == "Stations") | .Children[] | select( .Index==1 ) | .GuideId')
				if [ -z "$STATIONID" ] ; then
					echo "ERROR: no Station \"$2\" found on TuneIn"
					exit 1
				fi
			fi
		-s)
				usage
				exit 1
			fi
			SONG=$2
			shift
				ALBUM=$2
				ARTIST=$SONG
				shift
			fi
		-t)
				usage
				exit 1
			fi
			ASIN=$2
			shift
		-u)
				usage
				exit 1
			fi
			SEEDID=$2
			shift
		-v)
				usage
				exit 1
			fi
			HIST=$2
			shift
		-w)
				usage
				exit 1
			fi
			PLIST=$2
			shift
		-l)
			LOGOFF="true"
		-a)
			LIST="true"
		-i)
			TYPE="IMPORTED"
		-p)
			TYPE="PURCHASES"
		-P)
			PRIME="prime-playlist-browse-nodes"
		-S)
			PRIME="prime-sections"
		-q)
			QUEUE="true"
		-lastalexa)
			LASTALEXA="true"
		-h|-\?|--help)
			usage
			exit 0
			echo "ERROR: unknown option ${1}"
			usage
			exit 1
	esac
	shift
done
case "$COMMAND" in
	pause)
			COMMAND='{"type":"PauseCommand"}'
	play)
			COMMAND='{"type":"PlayCommand"}'
	next)
			COMMAND='{"type":"NextCommand"}'
	prev)
			COMMAND='{"type":"PreviousCommand"}'
	fwd)
			COMMAND='{"type":"ForwardCommand"}'
	rwd)
			COMMAND='{"type":"RewindCommand"}'
	shuffle)
			COMMAND='{"type":"ShuffleCommand","shuffle":"true"}'
	vol:*)
			VOL=${COMMAND##*:}
			# volume as integer!
			if [ $VOL -le 100 -a $VOL -ge 0 ] ; then
				COMMAND='{"type":"VolumeLevelCommand","volumeLevel":'${VOL}'}'
			else
				echo "ERROR: volume should be an integer between 0 and 100"
				usage
				exit 1
			fi
	speak:*)
			SEQUENCECMD='Alexa.Speak'
			TTS=$(echo ${COMMAND##*:} | ${SED} -r 's/[^-a-zA-Z0-9_.,?! ]//g' | sed 's/ /_/g')
			TTS=",\\\"textToSpeak\\\":\\\"${TTS}\\\""
	automation:*)
			SEQUENCECMD='automation'
			UTTERANCE=$(echo ${COMMAND##*:} | ${SED} -r 's/[^-a-zA-Z0-9_,?! ]//g')
	weather)
			SEQUENCECMD='Alexa.Weather.Play'
	traffic)
			SEQUENCECMD='Alexa.Traffic.Play'
	flashbriefing)
			SEQUENCECMD='Alexa.FlashBriefing.Play'
	goodmorning)
			SEQUENCECMD='Alexa.GoodMorning.Play'
	singasong)
			SEQUENCECMD='Alexa.SingASong.Play'
	tellstory)
			SEQUENCECMD='Alexa.TellStory.Play'
			echo "ERROR: unknown command \"${COMMAND}\"!"
			usage
			exit 1
esac
# Amazon Login
log_in()
# following headers are required:
#	Accept-Language	(possibly for determining login region)
#	User-Agent	(cURL wouldn't store cookies without)
rm -f ${DEVLIST}
rm -f ${COOKIE}
rm -f ${TMP}/.alexa.*.list
# get first cookie and write redirection target into referer
${CURL} ${OPTS} -s -D "${TMP}/.alexa.header" -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
 https://alexa.${AMAZON} | grep "hidden" | ${SED} 's/hidden/\n/g' | grep "value=\"" | ${SED} -r 's/^.*name="([^"]+)".*value="([^"]+)".*/\1=\2\&/g' > "${TMP}/.alexa.postdata"
# login empty to generate session
${CURL} ${OPTS} -s -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
 -H "$(grep 'Location: ' ${TMP}/.alexa.header | ${SED} 's/Location: /Referer: /')" -d "@${TMP}/.alexa.postdata" https://www.${AMAZON}/ap/signin | grep "hidden" | ${SED} 's/hidden/\n/g' | grep "value=\"" | ${SED} -r 's/^.*name="([^"]+)".*value="([^"]+)".*/\1=\2\&/g' > "${TMP}/.alexa.postdata2"
# login with filled out form
#  !!! referer now contains session in URL
${CURL} ${OPTS} -s -D "${TMP}/.alexa.header2" -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
 -H "Referer: https://www.${AMAZON}/ap/signin/$(awk "\$0 ~/.${AMAZON}.*session-id[ \\s\\t]+/ {print \$7}" ${COOKIE})" --data-urlencode "email=${EMAIL}" --data-urlencode "password=${PASSWORD}" -d "@${TMP}/.alexa.postdata2" https://www.${AMAZON}/ap/signin > "${TMP}/.alexa.login"
# check whether the login has been successful or exit otherwise
if [ -z "$(grep 'Location: https://alexa.*html' ${TMP}/.alexa.header2)" ] ; then
	echo "ERROR: Amazon Login was unsuccessful. Possibly you get a captcha login screen."
	echo " Try logging in to https://alexa.${AMAZON} with your browser. In your browser"
	echo " make sure to have all Amazon related cookies deleted and Javascript disabled!"
	echo
	echo " (For more information have a look at ${TMP}/.alexa.login)"
	rm -f ${COOKIE}
	rm -f "${TMP}/.alexa.header"
	rm -f "${TMP}/.alexa.header2"
	rm -f "${TMP}/.alexa.postdata"
	rm -f "${TMP}/.alexa.postdata2"
	exit 1
fi
# get CSRF
${CURL} ${OPTS} -s -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L\
 -H "Referer: https://alexa.${AMAZON}/spa/index.html" -H "Origin: https://alexa.${AMAZON}"\
 https://${ALEXA}/api/language > /dev/null
rm -f "${TMP}/.alexa.login"
# get JSON device list
get_devlist()
${CURL} ${OPTS} -s -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L\
 -H "Content-Type: application/json; charset=UTF-8" -H "Referer: https://alexa.${AMAZON}/spa/index.html" -H "Origin: https://alexa.${AMAZON}"\
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})"\
 "https://${ALEXA}/api/devices-v2/device?cached=false" > ${DEVLIST}
check_status()
# bootstrap with GUI-Version writes GUI version to cookie
#  returns among other the current authentication state
	AUTHSTATUS=$(${CURL} ${OPTS} -s -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L https://${ALEXA}/api/bootstrap?version=${GUIVERSION} | ${SED} -r 's/^.*"authenticated":([^,]+),.*$/\1/g')
	if [ "$AUTHSTATUS" = "true" ] ; then
		return 1
	fi
	return 0
# set device specific variables from JSON device list
set_var()
	DEVICE=$(echo ${DEVICE} | ${SED} -r 's/%20/ /g')
	if [ -z "${DEVICE}" ] ; then
		# if no device was supplied, use the first Echo(dot) in device list
		echo "setting default device to:"
		DEVICE=$(jq -r '[ .devices[] | select(.deviceFamily == "ECHO" or .deviceFamily == "KNIGHT" or .deviceFamily == "ROOK" ) | .accountName] | .[0]' ${DEVLIST})
		echo ${DEVICE}
	fi
	DEVICETYPE=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .deviceType' ${DEVLIST})
	DEVICESERIALNUMBER=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .serialNumber' ${DEVLIST})
	MEDIAOWNERCUSTOMERID=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .deviceOwnerCustomerId' ${DEVLIST})
	if [ -z "${DEVICESERIALNUMBER}" ] ; then
		echo "ERROR: unkown device dev:${DEVICE}"
		exit 1
	fi
# list available devices from JSON device list
list_devices()
	jq -r '.devices[].accountName' ${DEVLIST}
# execute command
# (SequenceCommands by Michael Geramb and Ralf Otto)
run_cmd()
if [ -n "${SEQUENCECMD}" ]
	then
		if [ "${SEQUENCECMD}" = 'automation' ] ; then
			 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X GET \
			 "https://${ALEXA}/api/behaviors/automations" > "${TMP}/.alexa.automation"
			AUTOMATION=$(jq --arg utterance "${UTTERANCE}" -r '.[] | select( .triggers[].payload.utterance == $utterance) | .automationId' "${TMP}/.alexa.automation")
			if [ -z "${AUTOMATION}" ] ; then
				echo "ERROR: no such utterance '${UTTERANCE}' in Alexa routines"
				rm -f "${TMP}/.alexa.automation"
				exit 1
			fi
			SEQUENCE=$(jq --arg utterance "${UTTERANCE}"  -rc '.[] | select( .triggers[].payload.utterance == $utterance) | .sequence' "${TMP}/.alexa.automation" | ${SED} 's/"/\\"/g' | ${SED} "s/ALEXA_CURRENT_DEVICE_TYPE/${DEVICETYPE}/g" | ${SED} "s/ALEXA_CURRENT_DSN/${DEVICESERIALNUMBER}/g" | ${SED} "s/ALEXA_CUSTOMER_ID/${MEDIAOWNERCUSTOMERID}/g" | ${SED} 's/ /_/g')
			echo "Running routine: ${UTTERANCE}"
			COMMAND="{\"behaviorId\":\"${AUTOMATION}\",\"sequenceJson\":\"${SEQUENCE}\",\"status\":\"ENABLED\"}"
		else
			echo "Sequence command: ${SEQUENCECMD}"
			COMMAND="{\"behaviorId\":\"PREVIEW\",\"sequenceJson\":\"{\\\"@type\\\":\\\"com.amazon.alexa.behaviors.model.Sequence\\\",\\\"startNode\\\":{\\\"@type\\\":\\\"com.amazon.alexa.behaviors.model.OpaquePayloadOperationNode\\\",\\\"type\\\":\\\"${SEQUENCECMD}\\\",\\\"operationPayload\\\":{\\\"deviceType\\\":\\\"${DEVICETYPE}\\\",\\\"deviceSerialNumber\\\":\\\"${DEVICESERIALNUMBER}\\\",\\\"locale\\\":\\\"${LANGUAGE}\\\",\\\"customerId\\\":\\\"${MEDIAOWNERCUSTOMERID}\\\"${TTS}}}}\",\"status\":\"ENABLED\"}"
		fi
		 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d ${COMMAND}\
		 "https://${ALEXA}/api/behaviors/preview"
else
	 "https://${ALEXA}/api/np/command?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}"
fi
# play TuneIn radio station
play_radio()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST\
 "https://${ALEXA}/api/tunein/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&guideId=${STATIONID}&contentType=station&callSign=&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play library track
play_song()
	if [ -z "${ALBUM}" ] ; then
		JSON="{\"trackId\":\"${SONG}\",\"playQueuePrime\":true}"
	else
		JSON="{\"albumArtistName\":\"${ARTIST}\",\"albumName\":\"${ALBUM}\"}"
	fi
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "${JSON}"\
 "https://${ALEXA}/api/cloudplayer/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}&shuffle=false"
# play library playlist
play_playlist()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"playlistId\":\"${PLIST}\",\"playQueuePrime\":true}"\
# play PRIME playlist
play_prime_playlist()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"asin\":\"${ASIN}\"}"\
 "https://${ALEXA}/api/prime/prime-playlist-queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play PRIME station
play_prime_station()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"seed\":\"{\\\"type\\\":\\\"KEY\\\",\\\"seedId\\\":\\\"${SEEDID}\\\"}\",\"stationName\":\"none\",\"seedType\":\"KEY\"}"\
 "https://${ALEXA}/api/gotham/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play PRIME historical queue
play_prime_hist_queue()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"deviceType\":\"${DEVICETYPE}\",\"deviceSerialNumber\":\"${DEVICESERIALNUMBER}\",\"mediaOwnerCustomerId\":\"${MEDIAOWNERCUSTOMERID}\",\"queueId\":\"${HIST}\",\"service\":null,\"trackSource\":\"TRACK\"}"\
 "https://${ALEXA}/api/media/play-historical-queue"
# show library tracks
show_library()
	OFFSET="";
	SIZE=50;
	TOTAL=0;
	FILE=${TMP}/.alexa.${TYPE}.list
	if [ ! -f ${FILE} ] ; then
		echo -n '{"playlist":{"entryList":[' > ${FILE}
		while [ 50 -le ${SIZE} ] ; do
 "https://${ALEXA}/api/cloudplayer/playlists/${TYPE}-V0-OBJECTID?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&size=${SIZE}&offset=${OFFSET}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" > ${FILE}.tmp
			OFFSET=$(jq -r '.nextResultsToken' ${FILE}.tmp)
			SIZE=$(jq -r '.playlist | .trackCount' ${FILE}.tmp)
			jq -r -c '.playlist | .entryList' ${FILE}.tmp >> ${FILE}
			echo "," >> ${FILE}
			TOTAL=$((TOTAL+SIZE))
		done
		echo "[]],\"trackCount\":\"${TOTAL}\"}}" >> ${FILE}
		rm -f ${FILE}.tmp
	fi
	jq -r '.playlist.trackCount' ${FILE}
	jq '.playlist.entryList[] | .[]' ${FILE}
# show Prime stations and playlists
show_prime()
	FILE=${TMP}/.alexa.${PRIME}.list
 "https://${ALEXA}/api/prime/{$PRIME}?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" > ${FILE}
		if [ "$PRIME" = "prime-playlist-browse-nodes" ] ; then
			for I in $(jq -r '.primePlaylistBrowseNodeList[].subNodes[].nodeId' ${FILE} 2>/dev/null) ; do
 "https://${ALEXA}/api/prime/prime-playlists-by-browse-node?browseNodeId=${I}&deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" >> ${FILE}
			done
		fi
	fi
	jq '.' ${FILE}
# current queue
show_queue()
	PARENT=""
	PARENTID=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .parentClusters[0]' ${DEVLIST})
	if [ "$PARENTID" != "null" ] ; then
		PARENTDEVICE=$(jq --arg serial ${PARENTID} -r '.devices[] | select(.serialNumber == $serial) | .deviceType' ${DEVLIST})
		PARENT="&lemurId=${PARENTID}&lemurDeviceType=${PARENTDEVICE}"
	fi
  "https://${ALEXA}/api/np/player?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}${PARENT}" | jq '.'
  "https://${ALEXA}/api/media/state?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}" | jq '.'
  "https://${ALEXA}/api/np/queue?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}" | jq '.'
# deletes a multiroom device
delete_multiroom()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X DELETE \
 "https://${ALEXA}/api/lemur/tail/${DEVICESERIALNUMBER}"
# creates a multiroom device
create_multiroom()
	JSON="{\"id\":null,\"name\":\"${LEMUR}\",\"members\":["
	for DEVICE in $CHILD ; do
		set_var
		JSON="${JSON}{\"dsn\":\"${DEVICESERIALNUMBER}\",\"deviceType\":\"${DEVICETYPE}\"},"
	done
	JSON="${JSON%,}]}"
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "${JSON}" \
 "https://${ALEXA}/api/lemur/tail"
# list bluetooth devices
list_bluetooth()
 "https://${ALEXA}/api/bluetooth?cached=false" | jq --arg serial "${DEVICESERIALNUMBER}" -r '.bluetoothStates[] | select(.deviceSerialNumber == $serial) | "\(.pairedDeviceList[]?.address) \(.pairedDeviceList[]?.friendlyName)"'
# connect bluetooth device
connect_bluetooth()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"bluetoothDeviceAddress\":\"${BLUETOOTH}\"}"\
 "https://${ALEXA}/api/bluetooth/pair-sink/${DEVICETYPE}/${DEVICESERIALNUMBER}"
# disconnect bluetooth device
disconnect_bluetooth()
 -H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST \
 "https://${ALEXA}/api/bluetooth/disconnect-sink/${DEVICETYPE}/${DEVICESERIALNUMBER}"
# device that sent the last command
# (by Markus Wennesheimer)
last_alexa()
${CURL} ${OPTS} -s -b ${COOKIE} -A "Mozilla/5.0" -H "DNT: 1" -H "Connection: keep-alive" -L\
 "https://${ALEXA}/api/activities?startTime=&size=1&offset=1" | jq -r '.activities[0].sourceDeviceIds[0].serialNumber' | xargs -i jq -r --arg device {} '.devices[] | select( .serialNumber == $device) | .accountName' ${DEVLIST}
# Serial number: | jq -r '.activities[0].sourceDeviceIds[0].serialNumber'
# Device name:   | jq -r '.activities[0].sourceDeviceIds[0].serialNumber' | xargs -i jq -r --arg device {} '.devices[] | select( .serialNumber == $device) | .accountName' ${DEVLIST}
# logout
log_off()
 https://${ALEXA}/logout > /dev/null
rm -f ${DEVLIST}
rm -f ${COOKIE}
if [ -z "$LASTALEXA" -a -z "$BLUETOOTH" -a -z "$LEMUR" -a -z "$PLIST" -a -z "$HIST" -a -z "$SEEDID" -a -z "$ASIN" -a -z "$PRIME" -a -z "$TYPE" -a -z "$QUEUE" -a -z "$LIST" -a -z "$COMMAND" -a -z "$STATIONID" -a -z "$SONG" -a -n "$LOGOFF" ] ; then
	echo "only logout option present, logging off ..."
	log_off
	exit 0
fi
if [ ! -f ${COOKIE} ] ; then
	echo "cookie does not exist. logging in ..."
	log_in
fi
check_status
if [ $? -eq 0 ] ; then
	echo "cookie expired, logging in again ..."
	log_in
	check_status
		echo "log in failed, aborting"
		exit 1
	fi
fi
if [ ! -f ${DEVLIST} ] ; then
	echo "device list does not exist. downloading ..."
	get_devlist
		echo "failed to download device list, aborting"
		exit 1
	fi
fi
if [ -n "$COMMAND" -o -n "$QUEUE" ] ; then
	if [ "${DEVICE}" = "ALL" ] ; then
		for DEVICE in $(jq -r '.devices[] | select( .deviceFamily == "ECHO" or .deviceFamily == "KNIGHT" or .deviceFamily == "ROOK" or .deviceFamily == "WHA") | .accountName' ${DEVLIST} | ${SED} -r 's/ /%20/g') ; do
			set_var
			if [ -n "$COMMAND" ] ; then
				echo "sending cmd:${COMMAND} to dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} customerid:${MEDIAOWNERCUSTOMERID}"
				run_cmd
			else
				echo "queue info for dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER}"
				show_queue
			fi
		done
	else
		set_var
			run_cmd
		else
			show_queue
		fi
	fi
elif [ -n "$LEMUR" ] ; then
	DEVICESERIALNUMBER=$(jq --arg device "${LEMUR}" -r '.devices[] | select(.accountName == $device and .deviceFamily == "WHA") | .serialNumber' ${DEVLIST})
	if [ -n "$DEVICESERIALNUMBER" ] ; then
		delete_multiroom
	else
		if [ -z "$CHILD" ] ; then
			echo "ERROR: ${LEMUR} is no multiroom device. Cannot delete ${LEMUR}".
			exit 1
		fi
	fi
		echo "Deleted multi room dev:${LEMUR} serial:${DEVICESERIALNUMBER}"
	else
		echo "Creating multi room dev:${LEMUR} member_dev(s):${CHILD}"
		create_multiroom
	fi
	rm -f ${DEVLIST}
	get_devlist
elif [ -n "$BLUETOOTH" ] ; then
	if [ "$BLUETOOTH" = "list" -o "$BLUETOOTH" = "List" -o "$BLUETOOTH" = "LIST" ] ; then
				set_var
				echo "bluetooth devices for dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER}:"
				list_bluetooth
			done
		else
			set_var
			list_bluetooth
		fi
	elif [ "$BLUETOOTH" = "null" ] ; then
		set_var
		echo "disconnecting dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} from bluetooth"
	else
		set_var
		echo "connecting dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} to bluetooth device:${BLUETOOTH}"
		connect_bluetooth
	fi
elif [ -n "$STATIONID" ] ; then
	set_var
	echo "playing stationID:${STATIONID} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
	play_radio
elif [ -n "$SONG" ] ; then
	set_var
	echo "playing library track:${SONG} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
	play_song
elif [ -n "$PLIST" ] ; then
	set_var
	echo "playing library playlist:${PLIST} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
	play_playlist
elif [ -n "$LIST" ] ; then
	echo "the following devices exist in your account:"
	list_devices
elif [ -n "$TYPE" ] ; then
	set_var
	echo -n "the following songs exist in your ${TYPE} library: "
	show_library
elif [ -n "$PRIME" ] ; then
	set_var
	echo "the following songs exist in your PRIME ${PRIME}:"
	show_prime
elif [ -n "$ASIN" ] ; then
	set_var
	echo "playing PRIME playlist ${ASIN}"
	play_prime_playlist
elif [ -n "$SEEDID" ] ; then
	set_var
	echo "playing PRIME station ${SEEDID}"
	play_prime_station
elif [ -n "$HIST" ] ; then
	set_var
	echo "playing PRIME historical queue ${HIST}"
elif [ -n "$LASTALEXA" ] ; then
	last_alexa
else
	echo "no alexa command received"
fi
if [ -n "$LOGOFF" ] ; then
	echo "logout option present, logging off ..."
	log_off
fi
Thanks. I have managed to get the alexa tts script running on my Raspberry Pi, following information from your guide and the GitHub repo. Took a little trial and error to get this working. I haven't tried getting it to work with Hubitat yet. One step at a time... :wink:
Glad you got it going. There seems to be lots of great options to use.
It also runs fine on a CentOS Linux (after installing jq)
I also "enhanced" the script by adding 3 lines around 293 or so...
  -C)
  	rm ${DEVLIST}
  	exit 0
also:
echo " -C : Clear Cached Device list
around line 135, so that -a could be made to work a 2nd time.
Yep, I had to install jq as well on Raspian Stretch to get it working.
I am able to run the "-a" command multiple times without any errors being thrown. Were you getting an error?
No, but I found I had named my Dots wrong and after changing them, the script wouldn't use the new names. They are cached in the file /tmp/.alexa_device_list.json
Delete it, and run the -a again, it fetches the new list, and caches that.
Ah, very nice! Thanks for the tip.
I have managed to get a node-red flow working that lets me pass in the text to speech as a parameter. It is working well from a browser.
HTTP switch here I come...
@ogiewon @csteele
Were either of you able to make this work without manually copying the cookie in?
I didn't even try it based on your feedback. I had to use Firefox with the cookie.txt extension to save the .alexa.cookie file.
I had no cookie hurdle. It just worked... for now.
So here is what I have so far, however it never seems to connect via Telnet. Nothing is ever logged from the parse() routine. This is my first attempt at using the new Telnet Capability in Hubitat, so I am sure I am doing something wrong.
@bravenel - Bruce, can you take a look and provide me with a hint on what to change? Have you tested the telnet capability with a Raspberry Pi yet? Any special things to be aware of? When I click Save on the Device Details page, it tries to connect via Telnet, however my Chrome browser shows the web page constantly being loaded (spinning activity indicator on the tab for the device.)
*   File: Alexa_TTS_Driver.groovy
*   Platform: Hubitat
*   Modification History:
*       Date       Who              What
*       2018-08-26 Dan Ogorchock    Original creation for Hubitat
*  Copyright 2018 Dan Ogorchock
*  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
*  in compliance with the License. You may obtain a copy of the License at:
*      http://www.apache.org/licenses/LICENSE-2.0
*  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
*  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
*  for the specific language governing permissions and limitations under the License.
def version() {"v0.1.20180826"}
preferences {
		input "ip", "text", title: "RPi IP Address", description: "IP Address in form '192.168.1.142'", required: true, displayDuringSetup: true
		input "port", "text", title: "RPi Telnet Port", description: "port in form of '23'", required: true, displayDuringSetup: true
		input "username", "text", title: "RPi Username", description: "username in form of 'pi'", required: true, displayDuringSetup: true
		input "password", "text", title: "RPi Password", description: "password in form of 'raspberry'", required: true, displayDuringSetup: true
		input "echoName", "text", title: "Echo Device Name", description: "Name of your echo in form of 'Kitchen'", required: true, displayDuringSetup: true
metadata {
    definition (name: "Alexa TTS", namespace: "ogiewon", author: "Dan Ogorchock") {
        capability "Speech Synthesis"
        capability "Telnet"
def installed() {
    initialize()
def updated() {
    log.debug "Attempting to close Telnet session"
    telnetClose()
    initialize()
def initialize() {
    state.version = version()
    log.debug "Attempting to connect via Telnet - IP = ${ip}, Port = ${port.toInteger()}, Username = ${username}, Password = ${password}"
    telnetConnect([termChars:[13,10]], ip, port.toInteger(), username, password)
    //give it a chance to start
	pauseExecution(1000)
def speak(message) {
    def msg = '/home/pi/ha-alexa-tts/alexa_remote_control.sh -d "' + "${echoName}" + '" -e speak:"' + "${message}" + '"\r\n'
    sendMsg(msg)
def sendMsg(String msg) {
    log.debug "Sending msg = ${msg}"
	return new hubitat.device.HubAction(msg, hubitat.device.Protocol.TELNET)
def parse(String msg) {
// process incoming telnet messages
    log.debug "Telnet Parse = ${msg}"
Indications seems to point trouble for people in the US with this. I restarted my pi and had to redo the process - not optimal :frowning:
On an up note using @ogiewon http momentary switch driver as a base, and my node red flow, I can now trigger my echo to speak through hubitat.
Try appending CR and LF to the string you're sending. I was having issue until I added it when trying to talk to the envisalink via Telnet.
Try this
//open telnet connection
		telnetConnect([termChars:[13,10]], ip, port, username, password)
This sounds a lot like what I was going through.
@ogiewon Isn't this the same as Pushover? Yea, different destination, but basically just pushing text to a "foreign" website.
It is similar. There is no web service listening on the RPi for this specific integration. It works great from the command line on the RPi, and via a Telnet session to the RPi. So, it seems like @cwwilson08 's idea to use Hubitat's built-in Telnet device driver capability work work well for this use-case.
