Whenever I ask Alexa to "turn down/up temperature"...the results are successful (temp goes up/down by 2 degrees) BUT I but Alexa responds that it was "not successful" and the following
appears in the logs:
groovy.lang.MissingPropertyException: No such property: toString for class: java.math.BigDecimal on line 769 (handleRequest)
[/quote]
I have tested with a virtual thermastate with the same results (to eliminate my device driver being the cause)
