Alexa skill in french canadian
Hello, any ETA for an french canadian Alexa Skill? Presently I only found the skill in english...
I try the Alexa Echo App but when I do a search device in Alexa app nothings is found...
If you set you phone to English, you will see it and be able to install it. Not sure what happens once you set it back to French though... Bonne chance!
The skill install but don't understand french commands...
Interesting - I use mine in English... I just tried it in French (My Alexa is setup to support both languages) and I can confirm that I see the same.
An option that would require some time to setup, but should work would be to program some French routines in Alexa that turn on / off the devices you want to use.
