Just migrated from Wink to Hubitat (loving it). Have a three enerwave z-wave relays controlling lights in my kitchen. They are grouped in Alexa app Into ”kitchen”. If I ask Alexa to turn on or off the kitchen lights it works perfectly, but the. Alexa says “sorry, kitchen is not responding”.
Never had problem with wink. Not sure where to look. All I could think of is that Hubitat not returning some status. ?
Note this was done following instruction on this community for independently controlling the two circuits within the relay.
This seems to be a random issue. I have some devices that won't have this problem for months and then out of the blue it will do it for a few days then it clears up. Others have reported this before also.
Since you have them grouped into "Kitchen" on the Amazon side, each of the devices is exposed to control on the Echo. Try using the Echo to control each relay individually and see if one of them is having an issue rather than the group.
I had the same problem popping up when I had a bad repeater with intermittent problems.
