I use an Emulator to simulate a Pixel phone. Through it, I can run HD+ and other apps without the PITA of a phone.
Today, I opened Amazon Alexa on the emulator and it stopped with a screen 'Upgrade Now'. It has no option to bypass, no way in or out but through. I will say it has been a thing that shows every time I open the app but it always had a 'Skip' button. So it seems Amazon maybe forcing the issue a lot of folks don't want to do. At least, I know I don't want it!
So I tried to find workarounds and the really only useful idea was to go throught, turn it on, then turn it back off after. I haven't done it yet - but I'm passing my AI search:
Yes, you are definitely not alone—there has been a massive wave of outrage over Amazon's aggressive push for Alexa+.
Android Authority
Amazon initiated automatic upgrades for Prime members. Recently, they tightened the app UI so the "Skip" or "Not Now" buttons were completely removed, effectively holding the app hostage behind a forced "Upgrade Now" screen. Users across Reddit and the official Amazon Forums have been venting about simple smart home controls breaking, added latency, unwanted conversational banter, and being forced into an AI layer they never asked for.
WTHR-TV
If the app refuses to let you past the setup screen, the prompt can be bypassed by completing the upgrade briefly and immediately stripping the account flag:
Step 1: Push "Upgrade Now" in the App
Accept the upgrade prompt in the app to clear the modal screen block. Because Alexa+ is included for Prime accounts during early access, accepting it will not charge your account. Once the prompt finishes loading, you will regain full access to your home controls and settings dashboard.
VICE
Step 2: Immediately Nuke Alexa+ via Voice
Once you are back into the standard app interface, walk over to any Echo device on your network and say:
"Alexa, exit Alexa Plus."
Android Authority
(or "Alexa, end early access to Alexa Plus.")
Ask Dave Taylor
Confirm "Yes" when prompted. This removes your account profile from the Alexa+ tier on Amazon's backend.
Step 3: Hard-Reset the Mobile App
Force-close the Alexa app on your phone (swipe it out of your recents menu) and reopen it. The app will sync with your updated account status and pull up the legacy interface without blocking your access again.
