alexa.garageDoorOpener vs alexa.ModeController
RIsking it - I have like one last item on my hub that is a peeve. I can't operate my garage door verbally through Alexa.
You can save yourself reading if you can answer 'Has HE worked on or changed Echo Skill since 2.4.4.156? I searched and don't see anything in the community about it.
Has anyone ever dug this deeply before or found a true way to make it work without trickery or deceit? I would so love that my GDO says 'opening' 'Open' 'closing' 'closed' as it is supposed to on the Alexa side so it reflects the truth of my GDO on the HE side. If you want to read further - feel free of course.
First, with echo skill set to 'Wait for Device' on my GDO - it operates perfectly in HE. When I share the device via ECho Skill to Amazon it shows as a garage door as expected, allows me to program a code blah blah. When I issue a verbal command I will ultimately get '... can't control go check on it' 1 minute later. The door operates but I always get the message which is ridiculously annoying and wrong.
I built a virtual driver that has a huge amount of test features - allowing me to control ever detail of response back, including milli delays etc as needed. I proved this is not the device at fault.
I tried to wirecap the dialog between Alexa and HE. I couldn't due to TLS encryption.
I tried to get logs on the Alexa side - only to learn that just the HE folks are allowed.
I turned to debug - and captured as much as I could and dug down to the dialog that way.
What I learned is that HE implemented Alexa.ModeController for GDO which require a different type of syncronous response. If a GDO were using Alexa.GarageDoorOpener it would work.
I simulated a Lock and bridge a lock to the GDO, and that is okay. But the verbal response to 'Open the Garage Door with 1234' gets you a 'The Garage Door is Unlocked' - so its still wrong.
Here is some AI response info after digging super deep (I spent 2 full work days on this testing the Device side before I came to conclude it wasn't a device issue):
"When the Echo Skill queries a Hubitat device's capabilities during discovery, its internal mapper follows fixed platform rules:capability "GarageDoorControl" Mapping:
Hubitat intentionally maps standard GarageDoorControl devices to Alexa's Alexa.ModeController interface with an instance identifier of GarageDoor.Position (using state values Position.Up and Position.Down). Hubitat designed it this way so Alexa treats garage doors as mode-based controllers rather than native locks/doors, avoiding mandatory PIN prompt requirements on voice opens in certain regional Alexa locales.
Why It Failed ("Device Unresponsive" & Silence)
Mapping Bug in Alexa.ModeController Response Builder:
Hubitat's Echo Skill presents the garage door to Alexa as an Alexa.ModeController (GarageDoor.Position) rather than a native Alexa.GarageDoorOpener or Alexa.LockController.
When the driver emits door: open synchronously, app:42 resolves the state to Position.Up. However, instead of constructing a valid Alexa.Response frame containing the updated mode payload and sending it back to AWS over the holding HTTP connection, the app silently drops the response frame or fails to serialize Position.Up."
(please do not suggest I hit Immediate - I know I could)
According to firmware release notes, yes.
thank you - seems release notes don't get searched for some reason! 2.5.1.180 looks to have a solve - I guess I'm compelled to move forward. thank you for looking that up.
Sure they do.
Upgrade to latest HE version - it still fails the same way. And made my hub wierd.
(thats just the echo debug)
Reverting back to 2.4.4.156
It definitely would not, as no such interface exists. Source: List of Alexa Interfaces and Supported Languages | Smart Home (I’d be curious to see the one you AI thinks it used :grinning_face: ). In fact, Amazon’s docs for ModeContoller specifically have an example for use with garage doors (see: Alexa.ModeController Interface 3 | Smart Home).
The “respond immediately” option is now per device, if you weren’t aware (I think something you even asked for?) and is intended specifically for cases like this, so I wouldn’t be hesitant to use it. But it’s possible something else is going on, too, and I’ll see if I can figure anything out.
