Alexa command works through HE but not via direct voice
This is not really a HE issue but wondered if anyone else has seen this. I have a automation that starts a stop watch on a Echo Show 10 that I have. The automation starts the stop watch using Echo Speaks. This has been working for a year or better. When I created this I guess I just assumed Alexa supported a stopwatch. Never had much need for for one but assumed its a simple task that would be there. The exact line in RM is:
voiceCmdAsText('Alexa, Start Egg cooker stopwatch') on Echo - Kitchen Show
--> delayed: 0:00:05
This also works on a Echo Show 8 that I have, if I send the above command it starts a stop watch on the screen I can see. If I speak this phrase to either Alexa device it responds with "That feature is not yet supported." Anyone seen any other phrase that works with Echo speaks but not via an actual voice command?
I asked AI and it also says Alexa does not support a stop watch but there are skills that enable it, but I don't have any stopwatch skills enabled. I just found it weird.
I just use a timer « Alexa, set a 2 minute timer » or « Alexa, 2 minutes » which works well… Is there something that the stopwatch does that a timer wouldn’t?
That’s what I was thinking. If you are cooking an egg, that would be a timer. If you were timing elapsed time of an event, that would be a stopwatch.
Is this after you’ve been downgraded to Alexa Plus, or did this also not work with good old functional, fast, and not overly annoying Alexa?
Yes I know how to use a timer. In this instance I use a small egg cooker that I have plugged into a smart plug. So when I start the cooker I just want to know how long it's been since I started it. The cooker stops automatically and when it does the power drops and it stops the stopwatch. It usually takes about 12 minutes. I just like to look over and see about how much longer it has.
I just found it odd that I can send a echo speaks command and it works but I can't speak the command. The only reason I noticed this was because the RM automation glitched last time I used it. When the cooker shut off, the rule did not see the trigger and stop the wait for power level. I manually turned off my smart plug and that stopped the rule but it did not turn off the stop watch. I am going to update the rule to fix that. The rule runs almost daily and it runs without error 99% of the time. I can't remember what I did now but I somehow changed the screen and the stop watch was no longer showing so I did not stop it manually either.
Today when the rule triggered and Echo speaks sent the command to start the stop watch, it said there was already a stop watch running. It was not on the screen and I could not figure out how to get it up on the screen manually. When I tried to stop it via voice it said there was no stop watch. When the egg cooker shut off this time and echo speaks sent the stop stopwatch command, the echo show said it stopped the stop watch with over a day of time on it, and it brought the stop watch up on the screen.
I created this rule some time ago, so maybe it's a Alexa+ thing. From searches I have tried they all indicate stopwatches are only available with third party skills but I don't remember ever installing one.
