It appears the System Alexa App went into a retry processing loop when Alexa returned a "Throttling Exception". Suggest adding a couple of seconds of delay before retrying when this error occurs.
Were you able to resolve the actual issue causing excessive pushes to Alexa? I had that issue for months before I finally tracked down the root cause.
