Alexa and dimmer
Does Hubitat work with Alexa and dimmer to control my LED hi hats. If so GE dimmer and how would I do it.
I’m guessing you mean can you ask Alexa to set the dimmer to a certain level? The answer is yes, for any dimmer. You can also uses phrases like higher, lower, raise, dim, up, etc.
Just add the dimmer to HE and expose it to Alexa via the Amazon Echo Skill in HE.
Thank you. I am doing a renovation and the switches will be moved 10 ft from couch. So I won't have to get up.
