Alarm Elimination time
I am new to hubitat. Liking it very much and not have too much trouble thanks to folks here. Can someone explain Alarm elimination time setting. I see this with my motion sensors but not sure what it means. I looked through the forum and setup docs but cannot find information. Thanks in advance.
Welcome to the forum!
I've not seen a setting labeled quite that way... however I'm going to guess it is one of two things.
(1) the amount of time the motion sensor has to wait after it stops sensing motion to report "inactive" back to the hub.
(2) the amount of time, once the motion sensor clears, that it waits before it can be re-triggered.
If you can post a screen shot of the device details that may yield additional info.
Thank you. Your answer makes sense. I will do some testing to see if in fact you are on the right track. If not I will post a screen shot of the device details.
