ts1234
1
I have the Radon sensor and the hub; values are updating but I still see this error in the log.
error - java.lang.NullPointerException: Cannot invoke method split() on null object on line 617 (method dataRefresh)
dev:6332025-01-11 09:03:04.856 AM
error - Read Error: status code: 404, reason phrase: Not Found
Any Ideas?
I assume you’re using @thebearmay’s driver?
ts1234
3
Yes. Sorry for not making it clear.
Guessing from the line number that it’s failing in the template processing, do you have a template file assigned?
ts1234
5
Thanks for the time. Yes, I did. No idea why. I've set that to "no selection."
I'll check the log in another hour.
