Airplay Integration, Pod Volume on Hub Reboot
I have a couple Apple iPods that I use for announcements using the Airplay Integration.
In the device settings there are fields to set the volume. If I set the volume from an app it sets the volume ok but doesn't update that field. Then If I reboot my hub the volume gets reset to what was in that field, not to what the volume was before.
For example: Set Volume (or Set Level) = 50. Pod volume is set to 50.
App does a poddevice.setVolume(70). Pod volume is set to 70 but set volume field still says 50.
Hub reboots. Pod Volume goes to 50.
To refresh this. Maybe no one else has this problem. Kinda a pain to reset volume on a reboot. Especially if the reboot occurs when I don’t know it. Which can happen on a low memory auto reboot.
I know I can write logic to save volume in a variable then restore on hub restart. Just puzzled a to why it should be necessary.
Guess I'm the only one with this issue.
Anyway, I wrote a routine to store the volume in a hub variable. Then I subscribed to 'systemStart'. I put a time delay of 30 seconds before resetting the volume to what was in the variable. But 30 seconds apparently not long enough. How long should it be?
