Air quality sensor to active sprinkler
Hello, I am completely new to Hubitat. I wanted to know if it is possible to use my amazon air quality sensor to be able to activate my Wyze irrigation system when it reaches a certain humidity or temperature, since the routines do not allow me to.
or know if there are other products that allow me to measure humidity and activate an irrigation system.
Are you sure temperature or humidity are the best triggers for a sprinkler controller?
I need something to control some vaporizers that will be in some rooms where it needs to be kept at 90% humidity and high temperature
If the devices can connect to Hubitat then yes -- if not well that's you answer.
