After the 2.1 update I have lost control of five of my six generic zig bee bulbs must I delete and rejoin? Anybody else seeing this problem?
I would try rejoin without deleting first.
This exactly. With zigbee you can factory reset the bulbs, but don’t remove them from Hubitat. Then you rediscover them and they will rejoin Hubitat under their original name and settings. It’s a big benefit of zigbee over z-wave.
Well doing a factory reset on bulb and trying to discover didnt work. had to remove it. Then it was found during discovery. I can turn it off and on from the devices page. But now when I try to put it back on the dashboard page I had it on, its not in the list. Grrr LOL. Went back to devices and status and its all there and works. Just can not add it to the dashboard. There was again an update and I was hoping it would fix it, but alas, it did not. Currently running version: 2.1.0.120
If you have the dashboard page open, and then add a device to your network (with it open), it will not automatically populate, you must refresh your browser on the dashboard page, and it will be there
Just discovered, its only on my light dashboard, when I am on another dashboard, it shows up in the list for devices and works on that dashboard. Just not the one I have all my lights on. Any suggestions?
This is classic bad router (or too few) buisness...
Reboot hub, device xyz finds a new parent, and a looser at that, device doesn't work now...
You reset the device, it manages to find the same looser parent it had last time, and won't join...
You remove the device from Hubitat, so now the route data from said looser parent is also scrubbed, and we're able to get it going again, until the next reboot...
I have refreshed the page, no difference, when adding with the + button, the device list only has 4 items on it. And only does it on that dashboard. Guess I could delete the dashboard and recreate...
I had the same issue. I only have battery motion sensors. The only parent would be
the hub.
I suspect the location I had it in. I’ve had trouble with it a couple times in the past, so I moved it to another wall.
I ended up deleting and re-adding it because a reset and a discover wouldn’t work.
I’ll keep an eye on it.
