I have 5 Aeotec tri-sensor ZWA-005A. Since my upgrade from C5 to C8, none of them work even after multiple factory resets.. They no longer report motion or the property battery level. I hate to scrap these, outside of their cost, these things have worked great. Replacing the batteries and everything has just stopped. Am I the only one?
After resetting them did you pair them back to the hub?
Can we see the z-wave details page (either just the sensors or the entire thing would be best).
That might be one of the sensors that pairs with S0 security.
Yes, I paired it back to the hub. It found it, I accepted it without security.
A screenshot from a larger screen would be much better.
It does look like the top two nodes shown are ghosts (no device attached), they could be causing some issues at the moment. Probably failed paring attempts (or the old nodes and you did not exclude properly). They are showing neighbors so you will have a hard time getting rid of them.
You could try shutting down the hub and removing power for 30 seconds before booting back up.
Otherwise I would need to see the whole z-wave details from a larger scren.
Ok I'll shut down the hub & remove power for 30 seconds and get back to you in a few minutes
Before you take the time to screenshot the entire z-wave details page, Let the hub run for at least a couple of hours. The data will be much more useful if we can see some of the metrics after the devices have been more active (reboot clears the metrics).
I should have said to screenshot it before you shut down, forgot about that part.
Ok so my day went left but I did restart it hours ago. I saw the motion working but not the illuminance or temperature. That lasted about 5 minutes, but even after hitting refresh it's not updating the motion. What can I screen shot to give you what u need.
The entire z-wave details page, multiple screen shots if needed.
Also, refresh is mostly useless on battery z-wave devices, or do you have this sensor plugged in?
