Aeotec Siren 6 Volume Control
The Aeotec Siren 6 Volume control no longer seems to work. Plays at full volume what ever you set the level too.
Is it just me or has anyone else noticed this?
Same here - I've also set the Tamper Volume to Mute and the Tamper Tone to None, makes no difference whatsoever!
Fast coming to the realisation that the Aeotec Siren 6 as a device is a real hit & miss!
Was working fine until the recent firmware updates. I've now managed to work around it. I've set the Siren Volume under preferences to Mute. I then use in Webcore the Set Volume and Play Sound options. Set Volume 1-100 and the sound number I want to play. Seems to be OK again. As I was already using those settings in Webcore all I had to actually change was the Siren Volume preference. Previously it was set to 100%.
