I’ve created over a dozen rules trying different things. Yet contact sensor button it’s hit and miss. It will stutter a chime. Reviewing events will sometimes show duplicate events which yes that would be a cause for those specific times but other times only one event and it will show a couple playing events even though there was one event.
I have one simple rule.
Button press play sound 29. That’s it and it sill cause stuttering. Not all the time but 1 out of 5 times.
I wondering if I should reset the whole siren and start over again.
It was causing triple sounds still when triggering it from the device itself.
Brought it in and now it’s workinf. I’m wondering if one of my plugs that maybe it was using may be causing an issue when it’s using it as a repeater ?
I may unplug all my zwave repeaters and repair and test again ?
This is a common issue with other chimes, which I explained in detail above, but I haven't experienced it with this device and I must have played hundreds of chimes while writing the handlers so it's most likely an issue with your mesh.
If you have the device joined secure, remove it, change the secure join option to locks in the z-wave settings, and add it again. If that fixes the problem then it's most likely not an issue with the device.
You can not control/change the zwave routing path.The device determines that on its own, and while it can be modified (technically, although that is not common) it is not user configurable in Hubitat.
Mine seems to be working on a very basic level with the stock handler, but I just wanted to confirm -- like my doorbell, can I upload MP3s to trigger, or no? I know I cannot do TTS.
Hello, very late to the discussion but I did receive one of these units to test. It didn't work properly with my Abode Gateway so I intend on trying it out on Hubitat when it isn't 12:48am. They recommended I use a SmarthingThings hub for testing, but I don't have one of those. I'll dig into all of your responses and see if I can figure it out. I'm very new to hubitat
