Noticed after the 2.2.2.123 platform update that the Aeotec Recessed Door Sensor 7 driver for all 3 of my Aeotec Recessed Door Sensor 7 devices is showing as "Deprecated". I don't recall seeing this before the update. Is anyone else seeing this? What driver are we supposed to use now? No errors in logs, operates fine.
Hi there, sorry for the confusion. All Aeotec Door Sensors 7 have been consolidated under one driver. You can continue to use the legacy driver, or change the Type to Aeotec Door/Window Sensor 7 Series.
Thanks. I didn’t see any announcement to that effect in the release notes. The supported devices list still shows that the driver should be the Recessed Door Sensor 7 driver. Same seems to apply to the Aeotec Door/Window Sensor 7, which also showed as “Deprecated”, and which also has an older name (Aeotec Door/Window Sensor) as the driver to use. Both types of devices changed from “Deprecated “ to ”System” when the driver was changed to the consolidated one you mentioned.
