Aeotec Pico Duo switch type configuration
Hi All,
I need some help configuring an Aeotec Pico Duo to work with momentary switches. The auto setup feature does not appear to be working despite multiple attempts, so I need to set the attribute manually. From the engineering sheet it appears that the attribute cluster and parameter values should be as follows;
But when I run this the logs appear to show the instruction is being skipped, and the switches still do not manually operate the device;
Where am I going wrong here? Should I be including the manufacturer ID in the cluster parameter? Is there another way to get these switches working correctly? Please help :folded_hands:
Problem solved, I used the Knockturn Alley driver to update the switch type clusters manually, worked really well despite the amusing command titles. For anyone that wants to manually update zigbee device attributes not exposed by the current drivers, this worked for me;
