Aeotec Nano switch - Overheat protection
Hi all,
I’m starting to see “ Overheat protection.” in the logs in hubitat for one Aeotec Nano device. It’s strange as I just moved the device to another location and it starting logging this event. The strange thing is, when I disconnect the output load I still see the alert. I also see the alert when the device is not switched ‘On’.
Anyone see this before ? I only use Aeotec hardware and I don’t see any other alerts. A minor difference in respect to the other devices is this device is near the floor where I have under floor heating. I’ve read the docs and it says “you will see this alert when the temp exceeds 100C” , I’m going to move the switch tomorrow and see what happens
Thanks.
