So I have two 1 gang boxes. one has a Zen 32 and the other has the Nano dimmer and the output to some string led lights. There is not enough room for the Nano dimmer and the Zen32 to be put in the same box.
Wiring diagram attached.
I am trying to use the relay in the Zen32 to turn on and off the string lights. I have made the assumption that the S1 switch on the Nano would be seeing the same voltage from the Zen as it would from it's own common out. Therefore by passing 120V to the S1 location I could simulate the same on/off function as when the common is connected to S1 via a switch (per Aeotec diagrams).
Having a neutral in the box with the Nano I assumed it would be using the neutral wire connection and not passing current through the LED string when it is turned off. Currently all LED's are just barely glowing when the device is turned off.
Would it make more since to connect the line in on the Nano to the Zen32 Load connection and just severing all power when the lights are turned off. How long will it take the device to rejoin the network after the power has been cut. I would probably set the Nano to return to last state before power fail, but it might take a minute or two to figure itself out.
Any other thoughts on how to make this system work.
