Aeotec Multisensor 6 Stuck on Initializing
I have a new Aeotec Multisensor 6 . When trying to discover the device Hubitat finds and then gets stuck on initializing. I have excluded the device and factory reset the device with the same results. Any hints on solving the problem?
I had that with one.. it was too far from the mesh. I moved it closer and it paired easy.
It is located 3 feet from the Hubitat hub. Still does not work.
Two items....
  1. apparently Hubitat says there is a fix for this in the next release... no date, but as you know, they pop out updates quickly.
  2. some have found success by clicking the device again, in the middle of the initialize. Imagine that the device went to sleep.. so you click it again and it wakes and carries on. Others say restarting the hub's discover helps... as if 60 seconds isn't enough and needs 120 seconds.
I have used 1) about 3 months ago on a Leviton Smart Dimmer. Got frustrated on the 7th attempt and just clicked the paddle. Completed discovery 4-5 seconds later!!
Thanks tried both and neither helped. Will wait for the next release.
