Aeotec AerQ T/H unsolicited report not working
I have just purchased and installed the Aeotec AerQ device on my C5. I see it is supported, but unfortunately I can't seem to get the unsolicited report feature to work. It doesn't seem to matter what I set this to, the reports only come in on the 15 minute intervals I have specified. The purpose of this is to run a bathroom fan when the shower is going, and a 15 minute delay is not acceptable. The specs show that it can send an unsolicited report when a change in temp or humidity is detected, and this is what I want. Unfortunately the logs just show the configured 15 minute poll reports.
Any ideas on how to diagnose and fix the problem?
disable the timed reports
Thanks, that did the trick. I should have read the spec sheet more closely. I had incorrectly understood that the unit would be checking the temp and humidity more often and only transmitting if there was a change. Ultimately, it won't do what I want for a shower fan trigger, but the secondary purpose is to monitor the temperature of a beehive, so 15 minutes is fine for that.
Most of my z-way devices report via changed & timed, it's weird this doesn't. I'm planning to use it for the bathroom fan too.
How do you do that?
In the settings of the device disable "Periodic Report Interval" and as per usual click on save preferences and then configure
Thanks mate. Sorry I figured it out and realised how silly my question was.. Thanks again for leaning in to help. I've just picked up my hub and devices and haven't been able to stop since.
I was suprised I can't get a graph showing the history of temp or humidity reading. Am I missing something here? Surely I should be able to see a graph woth history for the past x days hrs or min..
No worries. Hubitat has no built in charting only basic logging i.e. "events"
